- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
2 lights white 2 lights Amber xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2 lights white 2 lights Amber xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 118 DL and 11.7 UL with only one computer connected. Can I start connecting other computers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would either return the XR from where you got it and get another or ask NG for an RMA....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try. Won't hurt anything.
I'm using D-Link DGS-105/108 series. Non managed and non green ethernet. I think NG has similar GS seriers as well. 105/108
@TheMattMan wrote:
I started a return on the router, i will continue to mess with this one tonight. Do you think the speeds would be better if I ran a switch? And if so do you have a affordable brand you like?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speeds are the same with or without bufferbloat disabled. I've even tried to set up some nighthawk gaming setups and it makes no difference. I tried this with a little increase in speed https://www.letsplayindex.com/video/best-settings-netgear-xr500-nighthawk-gaming-router-ps4-mgRgNO7K... I am still staying amber on the ps4 with low speeds hanging in the 30mb with nothing else runing. Computers are all getting pretty decent speeds.
I should be getting a replacement tomorrow if the postal service will leave it, monday if not. I've always thought that the plug for the patch cable seemed a little iffy. I guess I will know soon enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok I received the new router and have it installed. I am ending up with similiar issues in that the PS4 is still showing amber and I am only getting speeds of 37-40mbs wired and 5G is getting speeds of 89mbs. Seems very strange, anyone have a solution to this? I can order more new cables, but I have 5 brand new cat6 cables and all of them are amber on the PS4 and white on any of the computers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried both with geo filtering on and off and it seems pretty similiar. I only play Destiny and I know the servers are in Las Vegas. So I can do a setup just for Destiny and it usually does a circle around Nevada. I ordered a switch today to see if it helps or not also. The ps4 should be a white led, cant figure out why it stays amber.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
