× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can’t connect to Internet with XR500
Koorsknight
So I just moved into my new apartment and had Fios TV/Internet setup before I moved in. I opted out of renting/buying their router since they really aren’t the greatest and wanted to use my own. I decided to buy a new XR500 to use Fios to maximize the gigabit Internet they offer. So now I’m trying to setup everything since I’ve settled in and I’m having issues connecting to the internet. My ONT box had an Ethernet cable coming out and coax going to it. Plugged the Ethernet WAN into the router and didn’t work. I’ve tried resetting both the ONT box and router multiple times and nothing works. I attempted to release the DCHP while connected directly to the ONT and that didn’t work either nor does it on the router. Really stumped right now since I had to convince my SO this was a smarter choice to get the router. Note: the ONT was already installed I’m assuming previous renters had Verizon.
Message 1 of 6
Guru
Re: Can’t connect to Internet with XR500
Try a factory reset and walk thru the setup wizard for the XR router using a wire connected PC and a web browser. See if the XR will connect to the ONT.
Has the ONT been powered OFF then back ON as well before setting up the XR router?
What is the Mfr and model# of the ISP ONT the NG router is connected too?
Message 2 of 6
Hate
Apprentice
The XR500 has some issue where you need to use a different MAC address initially when connecting to your Modem.
How I fixed it, was unplugging the modem, before you plug in the XR500 to it (via WAN port), then boot the Modem and all should work.
IF you plug it the XR500 directly into the modem (without unplugging), I had to spoof/change the Mac address to my old router...
Message 3 of 6
Guru
Any progress on this?
Message 4 of 6
Koorsknight
Still no luck with anything. I didn’t have much time to mess around with it since I’ve had to work late. I attached the picture of the model number and all. Going to try calling Verizon again to see if there is any issue on their end
Message 5 of 6
Guru
Ok, keep us posted. Ya, no model # information on that FIOS sticker. There nothing on the front top or bottom markings for model#?
Message 6 of 6
Discussion stats
  • 5 replies
  • 7508 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
