- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk Xr 500 pro gaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk Xr 500 pro gaming
Just press continue and let the router set up your connection. Do you want to use one SSID or have seperate 2.4 and 5Ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fair enough. once the XR500 has run a test for your connection it will ask for your ISP username and password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you do, let it run the test
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It will after its done configuring, also when asked you will see a tick box to have one network name untick that
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the XR500 plugged into Lan 1 on the BT modem and into the yellow port on the XR500? Try again to see if it will get settings, if not we can do it manually.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you asked the router to try again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It will say that, did you re-run the setup test?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay select manual setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
where it says does your intenet require a username and password tick yes, then enter it
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you do the internet setup? On wifi untick the box and it will seperate the wifi into two SSID's
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should did you select I want to set up my router? Instead of auto, also dont refresh browser. If you use an adblocker make sure thats turned off for the router setup and login by the way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
