× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
XR300 - MAC Whitelist
arnostko
Hello,
a while ago I bought the EX7300 and was surprised to learn that it does not support a MAC address whitelist for the wireless devices. Instead a whitelist should be configured on the router itself. As the WNDR3700 I used at that time only filtered wirelessly connected devices using the mac filter, this opened a potential security leak. I asked here:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7300-and-quot-positive-quot-MAC-ad...
So now I bought the XR300 and again can't find any way to allow access only for defined MAC addresses. Sure, I can block already connected devices, but what kind of security concept is this? First allowing a device to connect to the network and then be able to block it? Or am I missing something here?
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma_Alex
NetDuma Partner
Re: XR300 - MAC Whitelist
The XR300 doesn't support a whitelist feature unfortunately.
Message 2 of 4
arnostko
That is just "fantastic'! Why is it called a "PRO" Gaming Router then?
Nevermind, I never would have thought, that such an essential security feature will be ommited ever by a router in the 3rd millenium. I guess it is my fault for not doing the research and relying solely on the Netgear brand.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Because the features focus on what will help your gaming. MAC Whitelist won't affect that. I would assume that if you created a strong WiFi password then you wouldn't have devices potentially connecting that you don't recognise. This will be up to Netgear if they want to include it again.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1382 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
