× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR450 not giving full speeds on 2.4GHZ band
Billyfair
Tutor
Just bought an XR450 from Costcon on sale and relized it is not giving my full speeds on the 2.4GHZ band. I should be getting 100 down but instead i'm getting 80 down on this new router. My old Asus 87u router I bought 4 years ago would reach these speeds very easily on 2.4 GHZ band. None of the QOS is set up or anything on the XR450. Any suggestions why this is happening?
Message 1 of 61
Netduma_Jack
NetDuma Partner
Re: XR450 not giving full speeds on 2.4GHZ band
Usually 2.4GHz maxes out around this level. Is your device able to connect to the 5GHz?
You could try changing the channel in >Settings >Wireless to see if that improves it
Message 2 of 61
Billyfair
Tutor
The device does have 5 GHZ support. I was just surprised how this brand new router can't deliever the same speeds as my old 4 year old router.
Message 3 of 61
Guru
How is the router configured on 2.4Ghz?
What channels are you using? Auto or manual?
What security modes are you using?
Smart Connect enabled or disabled?
20/40Mhz Coexistance disabled?
FYI, I can also confirm that I'm only getting 100Mb down on my iphone 6sP on 2.4Ghz on a 200/10 ISP service. I get 230/10 speeds on 5Ghz and with SC enabled which of course the phone connects to the 5Ghz radio when SC is enabled.
Also tested manual channel and wifi security disabled as well. Still maxing out at 100Mb.
Using WiFi Sweetspot app on my phone, it's seeing about 200-250Mb connection speed rates between the phone and 2.4Ghz radio. I'm getting 900-1000mb + on 5Ghz radio.
Router bought 3 days ago and still using shipping FW. I have not updated FW as of yet. I'm wanting to test the router as shipped before doing any FW updates.
Specs:
XR500
AC2600 (800Mbps @2.4GHz—256QAM
support +1733Mbps @5Ghz 11ac)
XR450
• AC2400 (600Mbps@2.4GHz-64QAM
support+1733Mbps@5GHz 11ac)
If these are supposed to be connection rates between a device and the router, I'm not seeing it on the 450...
I'll try a different wifi device with the router and post results.
Message 4 of 61
Guru
Ok, with a Windows 7x64 PC connected to a D-Link DWA-192 USB 3.0 wireless adatper.
Windows showed the connection rate to be 450Mb between the adatper and 2.4Ghz radio:
I'm getting over 100Mb on the down: http://www.speedtest.net/result/7544572747
Definately closer to 200Mb for my ISP spec.
Connecting at 5Ghz, I'm seeing 1.3Gb connection rate between the adapter and 5Ghz radio: http://www.speedtest.net/result/7544587076
Seems that maybe there could be a problem with iPhones and the 2.4Ghz radio on the 450...
Message 5 of 61
Guru
Using a Mac Mini, it's wifi reports connecting at 195-220Mb on 2.4Ghz and 450Mb on 5ghz which I believe thats the Minis max connection rates.
2.4Ghz
http://www.speedtest.net/result/7544634184
5Ghz: http://www.speedtest.net/result/7544637056
2.4Ghz
Connecting my D-Link DWA-192 to the Mini: http://www.speedtest.net/result/7544623459
 Possible APPLE wifi issue with 2.4Ghz and the 450...
Message 6 of 61
Billyfair
Tutor
Manually set it to channel 6 (I have tried others too)
WPA2-PSK [AES]
Smart connect off
I tried doing both with no luck in increasing speeds
Message 7 of 61
Billyfair
Tutor
I am not using an Apple prodcut to test the speeds.
Message 8 of 61
Netduma-Fraser
NetDuma Partner
Did you use a WiFi analyser to find the least congested channel to change to? Do you have another device to test 2.4GHz wireless speed on?
Message 9 of 61
Billyfair
Tutor
I have done all of that.
Message 10 of 61
Netduma-Fraser
NetDuma Partner
What results did you get on other devices? May be the device doesn't support mu-mimo or beamforming so could disable those in Advanced WiFi settings. Otherwise would recommend contacting Netgears 24/7 support line
Message 11 of 61
Guru
What devices
are you using to test 2.4Ghz?
Message 12 of 61
Billyfair
Tutor
Pixel 2 XL and Nexus 6P
Message 13 of 61
Guru
Seems like some devices aren't working well on 2.4Ghz while one does. I'll see if I can find my 2.4ghz only wireless adatper and do some testing with it.
Would be nice to get some NG engineering eyes on this...
@DarrenM
@ChristineT
Message 14 of 61
Billyfair
Tutor
I am legit disappointed that this brand new router can't give me anywhere close to what my old router was giving me. I'm questioning if the software functions are even worth keeping the router.
Message 15 of 61
Guru
So far this is only on 2.4ghz. It is disappointing. I ask a friend who has a XR500 and he reports seeing the same thing with 2.4Ghz. 5Ghz is fine. I'm suprised no body else has caught this sooner.
I recommend you contact NG support and start a ticket. Reference this forum thread as well. Hoping someone will comment or give feedback from NG.
Message 16 of 61
Guru
Wanted to try a older 2.4Ghz 450Mb N only wireless adapter. TrendNet TEW-687GA.
Beamforming, SC and MIMO enabled on the XR450:
With SC and MIMO disabled on XR450:
With SC, MIMO and Beamforming disabled on the XR450:
Beamforming and MIMO enabled on the XR450:
Message 17 of 61
Billyfair
Tutor
The crazy thing is it doesn't even let me contact support when I enter my serial number on the website. It is just a blank field and doesn't let me click anything.
Message 18 of 61
Guru
I would either make contact with one of the forum moderators or phone contact NG support. I presume one of the forum moderators would be preferred...
Message 19 of 61
Netduma-Fraser
NetDuma Partner
Message 20 of 61
Guru
Yes, my R7800 is also registered thru there as well.
Message 21 of 61
Billyfair
Tutor
I did register through that website.
Message 22 of 61
Billyfair
Tutor
This is what i'm seeing when trying to conact support. (removed serial number from screenshot)
Message 23 of 61
Guru
My product serial number shows up, however when I click on one of the red X's, it brings up a window with warranty information, however the information is missing in the window so I don't know what the details are.
Message 24 of 61
Netduma-Fraser
NetDuma Partner
@DarrenM please help
Message 25 of 61
Top Contributors
Discussion stats
  • 60 replies
  • 4975 views
  • 11 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
