- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Wireless ACL - missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all, As I continue to configure the router, I realized the wireless acl is missing under advanced wireless settings. Was this function removed in the latest firmware version v2.2.1.10?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Wireless ACL - missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sad to hear this was removed. One reason for purchasing this router was due to having this ACL setting. Is it possible to obtain a previous firmware that still have this feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are versions available in the download area but I would not recommend it as you may encounter more issues than being on the latest version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the update. I did see previous versions on netgear support page and I did try using the last version before the current one which has the ACL page. Unfortunately as you said, had minor issues. I'm back on latest version and do hope this feature is becomes available in a fureture update. On a side note, I like to comment if this feature does come back, Guest network should not be affected if ACL is turned on. Guests should still be able to access without having the mac address on the list.
Thanks again!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
