- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 is not supporting 900Mb+- on the WAN to LAN test
- Mark as New
- Bookmark
- Subscribe
- Permalink
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test.
Seems like the HW NAT accelleration or Cut-Through that should be working on this router, isn't. This test is using the WAN port. I don't have any support for the SPF+ port.
XR700: v10, Windows 10x64
Running Speed Test...
BPS=381,173,408
0: 46,162,930 (369,303,440 bps)
1: 44,496,047 (355,968,376 bps)
2: 47,100,631 (376,805,048 bps)
3: 46,419,757 (371,358,056 bps)
4: 47,902,495 (383,219,960 bps)
5: 47,483,139 (379,865,112 bps)
6: 48,509,496 (388,075,968 bps)
7: 47,458,189 (379,665,512 bps)
8: 48,363,038 (386,904,304 bps)
9: 47,680,747 (381,445,976 bps)
10: 48,528,357 (388,226,856 bps)
11: 47,632,508 (381,060,064 bps)
12: 48,478,207 (387,825,656 bps)
13: 47,473,227 (379,785,816 bps)
14: 48,275,259 (386,202,072 bps)
15: 47,733,464 (381,867,712 bps)
16: 48,092,973 (384,743,784 bps)
17: 47,932,226 (383,457,808 bps)
18: 47,362,523 (378,900,184 bps)
19: 48,375,352 (387,002,816 bps)
XR700: v10, Windows 7
BPS=370,111,704
0: 44,791,390 (358,331,120 bps)
1: 44,476,968 (355,815,744 bps)
2: 44,770,552 (358,164,416 bps)
3: 46,073,590 (368,588,720 bps)
4: 45,812,470 (366,499,760 bps)
5: 45,489,110 (363,912,880 bps)
6: 46,676,541 (373,412,328 bps)
7: 46,873,684 (374,989,472 bps)
8: 45,990,023 (367,920,184 bps)
9: 47,038,243 (376,305,944 bps)
10: 46,390,556 (371,124,448 bps)
11: 46,761,893 (374,095,144 bps)
12: 46,330,190 (370,641,520 bps)
13: 46,808,975 (374,471,800 bps)
14: 46,297,395 (370,379,160 bps)
15: 46,644,519 (373,156,152 bps)
16: 46,267,153 (370,137,224 bps)
17: 46,920,449 (375,363,592 bps)
18: 46,876,910 (375,015,280 bps)
19: 46,515,924 (372,127,392 bps)
Loaded v14 beta, Windows 7, factory reset and setup from scratch, wifi disabled:
BPS=372,898,760
0: 46,459,875 (371,679,000 bps)
1: 46,512,486 (372,099,888 bps)
2: 47,031,920 (376,255,360 bps)
3: 46,212,546 (369,700,368 bps)
4: 46,866,362 (374,930,896 bps)
5: 46,458,028 (371,664,224 bps)
6: 46,832,136 (374,657,088 bps)
7: 46,135,983 (369,087,864 bps)
8: 46,692,523 (373,540,184 bps)
9: 46,193,505 (369,548,040 bps)
10: 47,229,294 (377,834,352 bps)
11: 46,099,476 (368,795,808 bps)
12: 47,013,490 (376,107,920 bps)
13: 46,064,165 (368,513,320 bps)
14: 47,087,509 (376,700,072 bps)
15: 46,921,037 (375,368,296 bps)
16: 45,983,186 (367,865,488 bps)
17: 46,753,098 (374,024,784 bps)
18: 46,342,874 (370,742,992 bps)
19: 47,203,540 (377,628,320 bps)
This would not be acceptable for users on a 1Gb ISP plan with this expensive top of the line NG gaming router.
My XR450 sees 900Mbps +
BPS=949,067,544
0: 118,942,890 (951,543,120 bps)
1: 118,632,281 (949,058,248 bps)
2: 118,632,793 (949,062,344 bps)
3: 118,634,072 (949,072,576 bps)
4: 118,636,572 (949,092,576 bps)
5: 118,630,824 (949,046,592 bps)
6: 118,638,303 (949,106,424 bps)
7: 118,634,627 (949,077,016 bps)
8: 118,636,011 (949,088,088 bps)
9: 118,631,677 (949,053,416 bps)
10: 118,632,337 (949,058,696 bps)
11: 118,632,660 (949,061,280 bps)
12: 118,635,038 (949,080,304 bps)
13: 118,634,658 (949,077,264 bps)
14: 118,631,777 (949,054,216 bps)
15: 118,634,063 (949,072,504 bps)
16: 118,637,281 (949,098,248 bps)
17: 118,628,200 (949,025,600 bps)
18: 118,628,983 (949,031,864 bps)
19: 118,630,948 (949,047,584 bps)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 is not supporting 900Mb+- on the WAN to LAN test
Nice job FURRYe38!
I report earlier this issue and I though I was the only who had this WAN Port not reaching the Gigabit speed on my XR700. Thank you for validating this problem with your WAN to LAN test!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is PPPoE/VLAN/IPv6 being used?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I forgot to add the link to this simple test program. Gives all details on how to run it:
https://www.duckware.com/tech/router-wan-to-lan-throughput-test.html
This is only to test WAN to LAN with no specialized configurations. Just a factory reset on the router with minimal setup using default settings only. I disabled WiFi since there is a easy access button for this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would presume results would be the same. I've tested with this more simplified program with other routers to compare.
Does NetDuma see same or similar speed results in there testing with the XR700?
iPerf Results:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 34.0 MBytes 285 Mbits/sec
[ 5] 1.00-2.00 sec 36.0 MBytes 301 Mbits/sec
[ 5] 2.00-3.01 sec 34.8 MBytes 291 Mbits/sec
[ 5] 3.01-4.01 sec 36.5 MBytes 305 Mbits/sec
[ 5] 4.01-5.01 sec 34.8 MBytes 291 Mbits/sec
[ 5] 5.01-6.01 sec 28.1 MBytes 236 Mbits/sec
[ 5] 6.01-7.01 sec 36.6 MBytes 307 Mbits/sec
[ 5] 7.01-8.01 sec 28.8 MBytes 240 Mbits/sec
[ 5] 8.01-9.02 sec 36.9 MBytes 308 Mbits/sec
[ 5] 9.02-10.02 sec 26.9 MBytes 225 Mbits/sec
[ 5] 10.02-11.02 sec 33.4 MBytes 279 Mbits/sec
[ 5] 11.02-12.02 sec 34.6 MBytes 290 Mbits/sec
[ 5] 12.02-13.03 sec 35.9 MBytes 300 Mbits/sec
[ 5] 13.03-14.03 sec 34.8 MBytes 291 Mbits/sec
[ 5] 14.03-15.06 sec 35.9 MBytes 292 Mbits/sec
[ 5] 15.06-16.06 sec 35.1 MBytes 294 Mbits/sec
[ 5] 16.06-17.11 sec 28.5 MBytes 229 Mbits/sec
[ 5] 17.11-18.11 sec 35.4 MBytes 295 Mbits/sec
[ 5] 18.11-19.12 sec 37.0 MBytes 309 Mbits/sec
Sent
[ 5] 0.00-20.00 sec 676 MBytes 283 Mbits/sec
Received
iperf Done.
Done.
Speed seems all over place. Still nothing much over 300Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
4 Parallel Streams set:
[ 5] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 6] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 7] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 8] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[SUM] 0.00-1.20 sec 7.50 MBytes 52.5 Mbits/sec
[ 5] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 6] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 7] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 8] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[SUM] 1.20-2.20 sec 7.50 MBytes 62.6 Mbits/sec
[ 5] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 6] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 7] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 8] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[SUM] 2.20-3.22 sec 7.50 MBytes 61.9 Mbits/sec
[ 5] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 3.22-4.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 4.23-5.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 5.23-6.24 sec 7.50 MBytes 62.2 Mbits/sec
[ 5] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 6] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 7] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 8] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[SUM] 6.24-7.27 sec 7.50 MBytes 61.5 Mbits/sec
[ 5] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 6] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 7] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 8] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[SUM] 7.27-8.27 sec 7.50 MBytes 62.9 Mbits/sec
[ 5] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 8.27-9.28 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 6] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 7] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 8] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[SUM] 9.28-10.29 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 6] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 7] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 8] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[SUM] 10.29-11.46 sec 7.50 MBytes 53.7 Mbits/sec
[ 5] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 6] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 7] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 8] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[SUM] 11.46-12.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 6] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 7] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 8] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[SUM] 12.47-13.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 6] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 7] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 8] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[SUM] 13.47-14.48 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 6] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 7] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 8] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[SUM] 14.48-15.50 sec 7.50 MBytes 61.8 Mbits/sec
[ 5] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 6] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 7] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 8] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[SUM] 15.50-16.68 sec 7.50 MBytes 53.5 Mbits/sec
[ 5] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 6] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 7] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 8] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[SUM] 16.68-17.85 sec 7.50 MBytes 53.6 Mbits/sec
[ 5] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 6] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 7] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 8] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[SUM] 17.85-18.99 sec 7.50 MBytes 55.2 Mbits/sec
[ 5] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 6] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 7] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 8] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[SUM] 18.99-20.07 sec 7.50 MBytes 58.5 Mbits/sec
Sent
[ 5] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 6] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 7] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 8] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Total sent
[SUM] 0.00-20.07 sec 392 MBytes 164 Mbits/sec
Total received
iperf Done.
Done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Put 1000/1000 in QoS and set to never and try again. Then also disable QoS completely in Anti-BB settings and try that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I run only CAT6 LAN cables. Same cables that tested the XR450 and other routers.
Those settings are default already after doing a factory reset. We expect routers to handle 900Mbps +- at factory defaults.
1 Stream:
[ 5] 0.00-1.00 sec 34.6 MBytes 290 Mbits/sec
[ 5] 1.00-2.00 sec 36.8 MBytes 308 Mbits/sec
[ 5] 2.00-3.00 sec 37.0 MBytes 310 Mbits/sec
[ 5] 3.00-4.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 4.01-5.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 5.01-6.01 sec 37.4 MBytes 313 Mbits/sec
[ 5] 6.01-7.01 sec 29.8 MBytes 249 Mbits/sec
[ 5] 7.01-8.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 8.01-9.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 9.02-10.02 sec 37.5 MBytes 314 Mbits/sec
[ 5] 10.02-11.02 sec 38.1 MBytes 319 Mbits/sec
[ 5] 11.02-12.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 12.02-13.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 13.02-14.03 sec 36.9 MBytes 308 Mbits/sec
[ 5] 14.03-15.03 sec 35.1 MBytes 294 Mbits/sec
[ 5] 15.03-16.03 sec 37.2 MBytes 312 Mbits/sec
[ 5] 16.03-17.03 sec 38.0 MBytes 318 Mbits/sec
[ 5] 17.03-18.04 sec 30.5 MBytes 255 Mbits/sec
[ 5] 18.04-19.04 sec 35.0 MBytes 292 Mbits/sec
[ 5] 19.04-20.04 sec 20.9 MBytes 175 Mbits/sec
[ 5] 20.04-21.04 sec 38.9 MBytes 325 Mbits/sec
[ 5] 21.04-22.05 sec 39.1 MBytes 327 Mbits/sec
[ 5] 22.05-23.21 sec 36.6 MBytes 263 Mbits/sec
[ 5] 23.21-24.22 sec 38.5 MBytes 322 Mbits/sec
[ 5] 24.22-25.22 sec 38.2 MBytes 320 Mbits/sec
[ 5] 25.22-26.22 sec 31.1 MBytes 260 Mbits/sec
[ 5] 26.22-27.23 sec 38.2 MBytes 321 Mbits/sec
[ 5] 27.23-28.23 sec 38.9 MBytes 326 Mbits/sec
[ 5] 28.23-29.23 sec 38.5 MBytes 322 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 1.05 GBytes 302 Mbits/sec
Received
iperf Done.
Done.
4 Stream:
[ 5] local 192.168.1.2 port 3661 connected to 192.168.0.136 port 5201
[ 6] local 192.168.1.2 port 3662 connected to 192.168.0.136 port 5201
[ 7] local 192.168.1.2 port 3663 connected to 192.168.0.136 port 5201
[ 8] local 192.168.1.2 port 3664 connected to 192.168.0.136 port 5201
[ 5] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 6] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 7] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 8] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[SUM] 0.00-1.17 sec 8.50 MBytes 61.0 Mbits/sec
[ 5] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 6] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 7] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 8] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[SUM] 1.17-2.19 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 6] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 7] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 8] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[SUM] 2.19-3.20 sec 8.50 MBytes 70.5 Mbits/sec
[ 5] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 6] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 7] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 8] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[SUM] 3.20-4.34 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 6] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 7] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 8] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[SUM] 4.34-5.37 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 6] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 7] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 8] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[SUM] 5.37-6.37 sec 8.50 MBytes 70.7 Mbits/sec
[ 5] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 6] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 7] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 8] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[SUM] 6.37-7.55 sec 8.50 MBytes 60.8 Mbits/sec
[ 5] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 6] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 7] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 8] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[SUM] 7.55-8.55 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 6] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 7] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 8] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[SUM] 8.55-9.71 sec 8.50 MBytes 61.6 Mbits/sec
[ 5] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 6] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 7] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 8] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[SUM] 9.71-10.71 sec 8.50 MBytes 71.2 Mbits/sec
[ 5] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 6] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 7] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 8] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[SUM] 10.71-11.73 sec 8.50 MBytes 69.9 Mbits/sec
[ 5] 11.73-12.85 sec 3.75 MBytes 28.0 Mbits/sec
[ 6] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 7] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 8] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[SUM] 11.73-12.85 sec 8.50 MBytes 63.5 Mbits/sec
[ 5] 12.85-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 6] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 7] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 8] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[SUM] 12.85-13.90 sec 8.50 MBytes 68.2 Mbits/sec
[ 5] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 6] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 7] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 8] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[SUM] 13.90-15.00 sec 8.50 MBytes 64.8 Mbits/sec
[ 5] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 6] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 7] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 8] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[SUM] 15.00-16.14 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 6] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 7] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 8] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[SUM] 16.14-17.14 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 6] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 7] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 8] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[SUM] 17.14-18.33 sec 8.50 MBytes 60.0 Mbits/sec
[ 5] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 6] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 7] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 8] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[SUM] 18.33-19.53 sec 8.50 MBytes 59.3 Mbits/sec
[ 5] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 6] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 7] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 8] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[SUM] 19.53-20.58 sec 8.50 MBytes 67.9 Mbits/sec
[ 5] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 6] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 7] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 8] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[SUM] 20.58-21.74 sec 8.50 MBytes 62.0 Mbits/sec
[ 5] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 6] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 7] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 8] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[SUM] 21.74-22.74 sec 8.50 MBytes 71.1 Mbits/sec
[ 5] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 6] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 7] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 8] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[SUM] 22.74-23.92 sec 8.50 MBytes 60.2 Mbits/sec
[ 5] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 6] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 7] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 8] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[SUM] 23.92-25.04 sec 8.50 MBytes 64.0 Mbits/sec
[ 5] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 6] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 7] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 8] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[SUM] 25.04-26.12 sec 8.50 MBytes 65.7 Mbits/sec
[ 5] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 6] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 7] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 8] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[SUM] 26.12-27.20 sec 8.50 MBytes 65.9 Mbits/sec
[ 5] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 6] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 7] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 8] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[SUM] 27.20-28.35 sec 8.50 MBytes 62.3 Mbits/sec
[ 5] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 6] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 7] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 8] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[SUM] 28.35-29.53 sec 8.50 MBytes 60.3 Mbits/sec
Sent
[ 5] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 6] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 7] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 8] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Total sent
[SUM] 0.00-30.20 sec 268 MBytes 74.3 Mbits/sec
Total received
iperf Done.
Done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is my XR450 test results: v40. Factory reset using default settings only.
XR450 and Duckware
BPS=948,560,264
0: 119,092,966 (952,743,728 bps)
1: 118,633,725 (949,069,800 bps)
2: 118,630,769 (949,046,152 bps)
3: 118,637,969 (949,103,752 bps)
4: 118,634,733 (949,077,864 bps)
5: 118,632,316 (949,058,528 bps)
6: 118,636,228 (949,089,824 bps)
7: 118,635,103 (949,080,824 bps)
8: 118,632,223 (949,057,784 bps)
9: 118,636,316 (949,090,528 bps)
10: 118,633,092 (949,064,736 bps)
11: 117,413,283 (939,306,264 bps)
12: 118,633,534 (949,068,272 bps)
13: 118,634,770 (949,078,160 bps)
14: 118,633,284 (949,066,272 bps)
15: 118,629,720 (949,037,760 bps)
16: 118,639,721 (949,117,768 bps)
17: 118,633,791 (949,070,328 bps)
18: 118,631,266 (949,050,128 bps)
19: 118,639,515 (949,116,120 bps)
XR450 and iPerf
1 Stream
[ 5] 0.00-1.00 sec 44.2 MBytes 370 Mbits/sec
[ 5] 1.00-2.01 sec 46.2 MBytes 386 Mbits/sec
[ 5] 2.01-3.01 sec 50.1 MBytes 419 Mbits/sec
[ 5] 3.01-4.01 sec 17.0 MBytes 142 Mbits/sec
[ 5] 4.01-5.02 sec 39.8 MBytes 332 Mbits/sec
[ 5] 5.02-6.02 sec 61.5 MBytes 515 Mbits/sec
[ 5] 6.02-7.02 sec 49.0 MBytes 410 Mbits/sec
[ 5] 7.02-8.02 sec 48.5 MBytes 406 Mbits/sec
[ 5] 8.02-9.02 sec 60.2 MBytes 504 Mbits/sec
[ 5] 9.02-10.03 sec 61.6 MBytes 516 Mbits/sec
[ 5] 10.03-11.03 sec 49.0 MBytes 410 Mbits/sec
[ 5] 11.03-12.03 sec 62.0 MBytes 519 Mbits/sec
[ 5] 12.03-13.03 sec 48.0 MBytes 402 Mbits/sec
[ 5] 13.03-14.03 sec 45.2 MBytes 379 Mbits/sec
[ 5] 14.03-15.04 sec 58.2 MBytes 488 Mbits/sec
[ 5] 15.04-16.04 sec 50.0 MBytes 419 Mbits/sec
[ 5] 16.04-17.04 sec 56.8 MBytes 476 Mbits/sec
[ 5] 17.04-18.21 sec 57.5 MBytes 410 Mbits/sec
[ 5] 18.21-19.38 sec 57.2 MBytes 413 Mbits/sec
[ 5] 19.38-20.40 sec 45.1 MBytes 370 Mbits/sec
[ 5] 20.40-21.40 sec 48.6 MBytes 407 Mbits/sec
[ 5] 21.40-22.41 sec 45.8 MBytes 383 Mbits/sec
[ 5] 22.41-23.41 sec 60.4 MBytes 506 Mbits/sec
[ 5] 23.41-24.41 sec 45.2 MBytes 379 Mbits/sec
[ 5] 24.41-25.41 sec 52.1 MBytes 437 Mbits/sec
[ 5] 25.41-26.41 sec 63.0 MBytes 528 Mbits/sec
[ 5] 26.41-27.41 sec 62.6 MBytes 525 Mbits/sec
[ 5] 27.41-28.41 sec 58.4 MBytes 489 Mbits/sec
[ 5] 28.41-29.41 sec 58.2 MBytes 488 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 1.50 GBytes 430 Mbits/sec
Received
iperf Done.
Done.
4 Stream:
[ 5] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 6] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 7] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 8] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[SUM] 0.00-1.00 sec 74.5 MBytes 623 Mbits/sec
[ 5] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 6] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 7] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 8] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[SUM] 1.00-2.01 sec 74.5 MBytes 622 Mbits/sec
[ 5] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 6] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 7] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 8] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[SUM] 2.01-3.01 sec 74.5 MBytes 621 Mbits/sec
[ 5] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 6] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 7] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 8] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[SUM] 3.01-4.02 sec 74.5 MBytes 624 Mbits/sec
[ 5] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 6] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 7] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 8] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[SUM] 4.02-5.05 sec 74.5 MBytes 604 Mbits/sec
[ 5] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 6] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 7] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 8] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[SUM] 5.05-6.05 sec 74.5 MBytes 623 Mbits/sec
[ 5] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 6] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 7] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 8] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[SUM] 6.05-7.06 sec 74.5 MBytes 622 Mbits/sec
[ 5] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 6] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 7] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 8] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[SUM] 7.06-8.06 sec 74.5 MBytes 624 Mbits/sec
[ 5] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 6] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 7] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 8] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[SUM] 8.06-9.06 sec 74.5 MBytes 623 Mbits/sec
[ 5] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 6] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 7] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 8] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[SUM] 9.06-10.07 sec 74.5 MBytes 623 Mbits/sec
[ 5] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 6] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 7] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 8] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[SUM] 10.07-11.07 sec 74.5 MBytes 624 Mbits/sec
[ 5] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 6] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 7] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 8] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[SUM] 11.07-12.07 sec 74.5 MBytes 624 Mbits/sec
[ 5] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 6] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 7] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 8] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[SUM] 12.07-13.08 sec 74.5 MBytes 621 Mbits/sec
[ 5] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 6] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 7] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 8] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[SUM] 13.08-14.08 sec 74.5 MBytes 623 Mbits/sec
[ 5] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 6] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 7] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 8] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[SUM] 14.08-15.08 sec 74.5 MBytes 624 Mbits/sec
[ 5] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 6] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 7] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 8] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[SUM] 15.08-16.08 sec 74.5 MBytes 622 Mbits/sec
[ 5] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 6] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 7] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 8] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[SUM] 16.08-17.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 6] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 7] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 8] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[SUM] 17.09-18.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 6] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 7] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 8] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[SUM] 18.09-19.09 sec 74.5 MBytes 623 Mbits/sec
[ 5] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 6] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 7] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 8] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[SUM] 19.09-20.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 6] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 7] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 8] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[SUM] 20.09-21.25 sec 74.5 MBytes 538 Mbits/sec
[ 5] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 6] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 7] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 8] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[SUM] 21.25-22.26 sec 74.5 MBytes 623 Mbits/sec
[ 5] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 6] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 7] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 8] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[SUM] 22.26-23.26 sec 74.5 MBytes 624 Mbits/sec
[ 5] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 6] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 7] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 8] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[SUM] 23.26-24.26 sec 74.5 MBytes 623 Mbits/sec
[ 5] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 6] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 7] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 8] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[SUM] 24.26-25.27 sec 74.5 MBytes 621 Mbits/sec
[ 5] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 6] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 7] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 8] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[SUM] 25.27-26.27 sec 74.5 MBytes 622 Mbits/sec
[ 5] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 6] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 7] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 8] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[SUM] 26.27-27.28 sec 74.5 MBytes 622 Mbits/sec
[ 5] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 6] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 7] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 8] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[SUM] 27.28-28.38 sec 74.5 MBytes 568 Mbits/sec
[ 5] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 6] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 7] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 8] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[SUM] 28.38-29.38 sec 74.5 MBytes 623 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 6] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 7] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 8] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Total sent
[SUM] 0.00-30.00 sec 1.96 GBytes 562 Mbits/sec
Total received
iperf Done.
Done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
XR450 and iPerf
5 Stream:
[ 5] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 6] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 7] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 8] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 9] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[SUM] 0.00-1.01 sec 60.6 MBytes 505 Mbits/sec
[ 5] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 6] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 7] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 8] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 9] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[SUM] 1.01-2.01 sec 60.6 MBytes 505 Mbits/sec
[ 5] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 6] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 7] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 8] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 9] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[SUM] 2.01-3.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 6] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 7] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 8] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 9] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[SUM] 3.02-4.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 6] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 7] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 8] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 9] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[SUM] 4.02-5.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 6] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 7] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 8] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 9] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[SUM] 5.02-6.03 sec 60.6 MBytes 505 Mbits/sec
[ 5] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 6] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 7] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 8] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 9] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[SUM] 6.03-7.03 sec 60.6 MBytes 507 Mbits/sec
[ 5] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 6] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 7] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 8] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 9] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[SUM] 7.03-8.04 sec 60.6 MBytes 506 Mbits/sec
[ 5] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 6] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 7] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 8] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 9] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[SUM] 8.04-9.04 sec 60.6 MBytes 507 Mbits/sec
[ 5] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 6] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 7] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 8] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 9] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[SUM] 9.04-10.04 sec 60.6 MBytes 508 Mbits/sec
[ 5] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 6] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 7] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 8] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 9] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[SUM] 10.04-11.05 sec 60.6 MBytes 506 Mbits/sec
[ 5] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 6] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 7] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 8] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 9] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[SUM] 11.05-12.20 sec 60.6 MBytes 442 Mbits/sec
[ 5] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 6] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 7] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 8] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 9] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[SUM] 12.20-13.20 sec 60.6 MBytes 508 Mbits/sec
[ 5] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 6] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 7] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 8] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 9] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[SUM] 13.20-14.20 sec 60.6 MBytes 508 Mbits/sec
[ 5] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 6] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 7] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 8] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 9] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[SUM] 14.20-15.21 sec 60.6 MBytes 505 Mbits/sec
[ 5] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 6] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 7] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 8] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 9] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[SUM] 15.21-16.21 sec 60.6 MBytes 508 Mbits/sec
[ 5] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 6] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 7] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 8] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 9] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[SUM] 16.21-17.22 sec 60.6 MBytes 506 Mbits/sec
[ 5] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 6] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 7] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 8] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 9] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[SUM] 17.22-18.22 sec 60.6 MBytes 506 Mbits/sec
[ 5] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 6] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 7] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 8] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 9] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[SUM] 18.22-19.22 sec 60.6 MBytes 508 Mbits/sec
[ 5] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 6] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 7] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 8] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 9] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[SUM] 19.22-20.23 sec 60.6 MBytes 506 Mbits/sec
[ 5] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 6] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 7] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 8] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 9] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[SUM] 20.23-21.23 sec 60.6 MBytes 506 Mbits/sec
[ 5] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 6] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 7] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 8] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 9] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[SUM] 21.23-22.24 sec 60.6 MBytes 505 Mbits/sec
[ 5] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 6] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 7] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 8] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 9] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[SUM] 22.24-23.25 sec 60.6 MBytes 506 Mbits/sec
[ 5] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 6] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 7] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 8] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 9] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[SUM] 23.25-24.25 sec 60.6 MBytes 508 Mbits/sec
[ 5] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 6] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 7] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 8] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 9] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[SUM] 24.25-25.25 sec 60.6 MBytes 507 Mbits/sec
[ 5] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 6] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 7] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 8] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 9] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[SUM] 25.25-26.25 sec 60.6 MBytes 507 Mbits/sec
[ 5] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 6] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 7] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 8] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 9] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[SUM] 26.25-27.26 sec 60.6 MBytes 507 Mbits/sec
[ 5] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 6] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 7] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 8] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 9] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[SUM] 27.26-28.26 sec 60.6 MBytes 507 Mbits/sec
[ 5] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 6] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 7] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 8] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 9] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[SUM] 28.26-29.27 sec 60.6 MBytes 506 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 6] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 7] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 8] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 9] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Total sent
[SUM] 0.00-30.00 sec 2.16 GBytes 618 Mbits/sec
Total received
iperf Done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hoping to see improvements on the XR700.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to make a small correction with my initial test results.
Those initial iPerf test results posted were testing the uplink speed of the WAN port. I wasn't paying attention when the test was running however looking at a network speed meter I have on my test PCs they show which direction the data flow is going, Up or DL. I didn't relize that the configuration of the PC thru the router and switch and how iPerf works and I had it configured, it seems having the iPerf Server configured on the PC thats connected to the switch and the iPerf client PC connected to the router under test, the direction of data flow is for the UP link speed. Changing the iPerf settings on the PC thats connected to the LAN switch to Client and the PC thats connected to the router under test to Server, this sends the data flow as DOWNLOAD link speed.
So after checking things again, I reset the XR router again and ensured the PCs and iPerf was confgured for the DOWNLOAD speed test. Still not seeing anything close to 900mpbs unfortunately.
Download Router mode
1 Stream
[ 5] 0.00-1.03 sec 25.1 MBytes 204 Mbits/sec
[ 5] 1.03-2.03 sec 30.1 MBytes 252 Mbits/sec
[ 5] 2.03-3.03 sec 38.8 MBytes 325 Mbits/sec
[ 5] 3.03-4.03 sec 38.9 MBytes 326 Mbits/sec
[ 5] 4.03-5.04 sec 37.9 MBytes 316 Mbits/sec
[ 5] 5.04-6.04 sec 22.9 MBytes 191 Mbits/sec
[ 5] 6.04-7.04 sec 31.2 MBytes 262 Mbits/sec
[ 5] 7.04-8.04 sec 38.8 MBytes 324 Mbits/sec
[ 5] 8.04-9.05 sec 31.6 MBytes 265 Mbits/sec
[ 5] 9.05-10.05 sec 38.5 MBytes 323 Mbits/sec
[ 5] 10.05-11.05 sec 38.2 MBytes 320 Mbits/sec
[ 5] 11.05-12.05 sec 23.4 MBytes 196 Mbits/sec
[ 5] 12.05-13.05 sec 31.4 MBytes 262 Mbits/sec
[ 5] 13.05-14.06 sec 39.2 MBytes 328 Mbits/sec
[ 5] 14.06-15.06 sec 38.5 MBytes 322 Mbits/sec
[ 5] 15.06-16.06 sec 31.2 MBytes 261 Mbits/sec
[ 5] 16.06-17.07 sec 38.9 MBytes 325 Mbits/sec
[ 5] 17.07-18.07 sec 38.9 MBytes 326 Mbits/sec
[ 5] 18.07-19.07 sec 31.2 MBytes 262 Mbits/sec
[ 5] 19.07-20.07 sec 30.1 MBytes 252 Mbits/sec
[ 5] 20.07-21.07 sec 30.1 MBytes 252 Mbits/sec
[ 5] 21.07-22.08 sec 21.8 MBytes 182 Mbits/sec
[ 5] 22.08-23.08 sec 29.1 MBytes 244 Mbits/sec
[ 5] 23.08-24.08 sec 31.2 MBytes 261 Mbits/sec
[ 5] 24.08-25.08 sec 38.6 MBytes 323 Mbits/sec
[ 5] 25.08-26.08 sec 38.8 MBytes 324 Mbits/sec
[ 5] 26.08-27.09 sec 31.2 MBytes 262 Mbits/sec
[ 5] 27.09-28.09 sec 31.0 MBytes 260 Mbits/sec
[ 5] 28.09-29.09 sec 37.4 MBytes 313 Mbits/sec
[ 5] 29.09-30.09 sec 30.0 MBytes 251 Mbits/sec
Sent
[ 5] 0.00-30.33 sec 996 MBytes 275 Mbits/sec
Received
4 Stream
[ 5] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
[ 6] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
[ 7] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
[ 8] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
[SUM] 0.00-1.02 sec 20.2 MBytes 167 Mbits/sec
[ 5] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[ 6] 1.02-2.02 sec 5.38 MBytes 45.0 Mbits/sec
[ 7] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[ 8] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[SUM] 1.02-2.02 sec 20.2 MBytes 169 Mbits/sec
[ 5] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[ 6] 2.02-3.02 sec 6.12 MBytes 51.3 Mbits/sec
[ 7] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[ 8] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[SUM] 2.02-3.02 sec 20.2 MBytes 170 Mbits/sec
[ 5] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[ 6] 3.02-4.03 sec 1.62 MBytes 13.6 Mbits/sec
[ 7] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[ 8] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[SUM] 3.02-4.03 sec 20.2 MBytes 169 Mbits/sec
[ 5] 4.03-5.03 sec 1.88 MBytes 15.7 Mbits/sec
[ 6] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[ 7] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[ 8] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[SUM] 4.03-5.03 sec 20.2 MBytes 170 Mbits/sec
[ 5] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 6] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 7] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 8] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[SUM] 5.03-6.03 sec 20.2 MBytes 169 Mbits/sec
[ 5] 6.03-7.03 sec 4.00 MBytes 33.5 Mbits/sec
[ 6] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[ 7] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[ 8] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[SUM] 6.03-7.03 sec 20.2 MBytes 170 Mbits/sec
Sent
[ 5] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 6] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 7] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 8] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Total sent
[SUM] 0.00-30.34 sec 392 MBytes 109 Mbits/sec
Total received
Duckware still reports same:
BPS=370,396,672
0: 43,215,838 (345,726,704 bps)
1: 44,711,842 (357,694,736 bps)
2: 45,684,960 (365,479,680 bps)
3: 46,070,614 (368,564,912 bps)
4: 46,952,917 (375,623,336 bps)
5: 46,035,429 (368,283,432 bps)
6: 46,825,266 (374,602,128 bps)
7: 46,501,707 (372,013,656 bps)
8: 46,668,326 (373,346,608 bps)
9: 46,320,527 (370,564,216 bps)
10: 46,748,672 (373,989,376 bps)
11: 46,432,389 (371,459,112 bps)
12: 45,312,645 (362,501,160 bps)
13: 46,491,542 (371,932,336 bps)
14: 46,208,458 (369,667,664 bps)
15: 46,506,975 (372,055,800 bps)
16: 46,208,476 (369,667,808 bps)
17: 46,794,457 (374,355,656 bps)
18: 46,392,063 (371,136,504 bps)
19: 46,824,360 (374,594,880 bps)
- Mark as New
- Bookmark
- Subscribe
- Permalink
As a side test, I had my XR700 in AP mode and wanted to see what speeds were seen while in this mode:
Download Speed AP mode
4 Stream
[ 5] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
[ 6] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
[ 7] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
[ 8] 0.00-1.12 sec 2.12 MBytes 15.9 Mbits/sec
[SUM] 0.00-1.12 sec 8.88 MBytes 66.5 Mbits/sec
[ 5] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
[ 6] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
[ 7] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
[ 8] 1.12-2.36 sec 2.62 MBytes 17.7 Mbits/sec
[SUM] 1.12-2.36 sec 8.88 MBytes 59.9 Mbits/sec
[ 5] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
[ 6] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
[ 7] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
[ 8] 2.36-3.43 sec 1.88 MBytes 14.7 Mbits/sec
[SUM] 2.36-3.43 sec 8.88 MBytes 69.4 Mbits/sec
[ 5] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
[ 6] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
[ 7] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
[ 8] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
[SUM] 3.43-4.53 sec 8.88 MBytes 68.1 Mbits/sec
[ 5] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
[ 6] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
[ 7] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
[ 8] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
[SUM] 4.53-5.66 sec 8.88 MBytes 65.9 Mbits/sec
Sent
[ 5] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
Received
Sent
[ 6] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
Received
[ 6] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
Sent
[ 7] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
Received
[ 7] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
Sent
[ 8] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
Received
[ 8] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
Total sent
[SUM] 0.00-30.29 sec 230 MBytes 63.8 Mbits/sec
Total received
[SUM] 0.00-30.29 sec 230 MBytes 63.7 Mbits/sec
UpSpeed AP mode
4 Stream
bin/iperf3.exe -c 192.168.0.136 -P 4 -i 1 -p 5201 -f m -t 20
Connecting to host 192.168.0.136, port 5201
[ 5] local 192.168.0.148 port 2881 connected to 192.168.0.136 port 5201
[ 6] local 192.168.0.148 port 2882 connected to 192.168.0.136 port 5201
[ 7] local 192.168.0.148 port 2883 connected to 192.168.0.136 port 5201
[ 8] local 192.168.0.148 port 2884 connected to 192.168.0.136 port 5201
[SUM] 0.00-1.00 sec 74.5 MBytes 624 Mbits/sec
[ 5] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
[ 6] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
[ 7] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
[ 8] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
[SUM] 1.00-2.00 sec 74.5 MBytes 624 Mbits/sec
[ 5] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
[ 6] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
[ 7] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
[ 8] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
[SUM] 2.00-3.01 sec 74.5 MBytes 621 Mbits/sec
[ 5] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
[ 6] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
[ 7] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
[ 8] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
[SUM] 3.01-4.08 sec 74.5 MBytes 585 Mbits/sec
[ 5] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
[ 6] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
[ 7] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
[ 8] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
[SUM] 4.08-5.08 sec 74.5 MBytes 624 Mbits/sec
Sent
[ 5] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
Received
Sent
[ 6] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
Received
Sent
[ 7] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
Received
Sent
[ 8] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
Received
Total sent
[SUM] 0.00-20.03 sec 1.34 GBytes 574 Mbits/sec
Total received
Seeing around 600Mpbs here.
It's interesting that Duckwares test saw 900mbps while in AP mode:
BPS=945,153,424
0: 118,618,928 (948,951,424 bps)
1: 118,005,184 (944,041,472 bps)
2: 118,211,457 (945,691,656 bps)
3: 118,307,869 (946,462,952 bps)
4: 118,317,792 (946,542,336 bps)
5: 118,320,105 (946,560,840 bps)
6: 117,452,558 (939,620,464 bps)
7: 118,312,032 (946,496,256 bps)
8: 118,319,123 (946,552,984 bps)
9: 118,246,052 (945,968,416 bps)
10: 117,973,528 (943,788,224 bps)
11: 117,933,981 (943,471,848 bps)
12: 118,321,485 (946,571,880 bps)
13: 117,904,900 (943,239,200 bps)
14: 118,323,900 (946,591,200 bps)
15: 118,319,751 (946,558,008 bps)
16: 117,919,242 (943,353,936 bps)
17: 118,305,083 (946,440,664 bps)
18: 118,313,001 (946,504,008 bps)
19: 117,931,813 (943,454,504 bps)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:It's interesting that Duckwares test saw 900mbps while in AP mode:
BPS=945,153,424
I saw another interesting thing too in the setup wizard at the Checking internet speed on the WAN Port, the speedtest can read the correct speed at 940Mbps/50Mbps and sometime is totally way off. Once the setup is done and you redo a speed test, you can't get the gigabit speed on ISP speed test or speedtest.net.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, hoping to hear back soon. Have a great weekend. Thank you.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
