Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 Good signal, bad connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-28
03:54 AM
2021-12-28
03:54 AM
Hi,
I Have a good signal at my bed room but the connection is really bad. If i go closer to the router the connection are fixed. In the beginning work perfectly, but now start work fine like a minute and start lost connection to internet.
Solved! Go to Solution.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-29
03:56 AM
2021-12-29
03:56 AM
I use smart connect, I try without smartconnect to check if the problem is resolved with this.
Message 3 of 3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-28
07:49 AM
2021-12-28
07:49 AM
Re: Xr500 Good signal, bad connection
Are you using Smart Connect for WiFi or connecting to 2.4/5GHz manually? It may be that there are more WiFi networks in your area now and so it may be beneficial to use a WiFi analyzer to find the least congested channel and change to that.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-29
03:56 AM
2021-12-29
03:56 AM
Message 3 of 3
Announcements
