× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
call of duty not filtered on geo filter for PC Xr1000
ggabir2
Geo-Filter - DumaOS and 3 more pages - Personal - Microsoft​ Edge 11_20_2022 7_25_26 AM.png
Message 1 of 24
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: call of duty not filtered on geo filter for PC Xr1000
Thanks for that, remove the PC from the Geo-Filter, then in the Device Manager change the PC to a PlayStation device type then re-add to the Geo-Filter and select the manual option then you should be able to filter.
Message 10 of 24
All Replies
Netduma-Fraser
NetDuma Partner
I can't see the picture until it's been moderated, can you add it as an attachment please?
Message 2 of 24
ggabir2
Message 3 of 24
ggabir2
Can u see it now?
Message 4 of 24
Netduma-Fraser
NetDuma Partner
No, try using imgur or a different photo upload site and post the link here instead
Message 5 of 24
ggabir2
Message 6 of 24
ggabir2
Just tried it again.
Message 7 of 24
Netduma-Fraser
NetDuma Partner
Still not working, use imgur and post the link
Message 8 of 24
ggabir2
https://imgur.com/a/4dYruPl heres the link
Message 9 of 24
Netduma-Fraser
NetDuma Partner
Message 10 of 24
ggabir2
So even if I game on pc. I should follow these steps?
Message 11 of 24
Netduma-Fraser
NetDuma Partner
Yes that's right
Message 12 of 24
Retired_Member
Not applicable
It also happens to me it says that it's incompatible but it should be compatible
Message 13 of 24
Netduma-Fraser
NetDuma Partner
Do the above and it will definitely work for you
Message 14 of 24
Retired_Member
Not applicable
Seriously, I shouldn't have to do that
Message 15 of 24
ggabir2
Right! Makes me think this router isn’t for gaming pc but for consoles if this is the case.
Message 16 of 24
Retired_Member
Not applicable
True true. I really shouldn't have to do that though. They should make it fully compatible for gaming PCs and stuff
Message 17 of 24
ggabir2
Yeah.
Message 18 of 24
Retired_Member
Not applicable
What games do you play though? By the way, I have an XR 450 and it still does this
Message 19 of 24
ggabir2
I have a xr1000 and I play all call of duty’s.
Message 20 of 24
Retired_Member
Not applicable
Same want to add me
Message 21 of 24
Netduma-Fraser
NetDuma Partner
It is the easiest way to filter on PC without changing services every time you want to play a different game, otherwise you can just use the service and switch it to filtering mode
Message 22 of 24
ggabir2
Yeah I can add you I also got the best settings lmk if you want them for your router
Message 23 of 24
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Message 24 of 24
Discussion stats
  • 23 replies
  • 3732 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
