× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
High frequency noise from SX10
junyih
Follower
Hi,
I just bought a GS810EMX SX10 two days ago, it works fine, and feels solid in hands.
One thing annoying me is, there is high frequency noise from the switch, and the buzz gets louder when i turn on LEDs.
One reason to choose this switch bcz it is fanless, now it is on the desktop i can hear it always.
I would like to ask:
  • If this is a quiality issue? is there something wrong? coils?
  • would it get worse in a long run, affecting the stability of the switch?
Thanks if anyone has ideas.
Model: GS810EMX|10 Port Nighthawk 10-Multigigabit Uplinks Ethernet Plus Switch
Message 1 of 2
Accepted Solutions
schumaku
Guru
Re: High frequency noise from SX10
Reads like a hardware issue on your device. Depending on your market, request a replacement unit from your retailer or via https://my.netgear.com/ -> My Support -> Contact Support -> Replace my defective product
Message 2 of 2
All Replies
schumaku
Guru
Message 2 of 2
Discussion stats
  • 1 reply
  • 2112 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
