Orbi WiFi 7 RBE973
Reply
2 Netgear routers
greenbob
2 Netgear routers
  Is there any benefit to combining my older AC2350 Nighthawk R7500 to the newer Nighthawk AX6 AX4300 model Rax45? We have a mid to large 2 story home with just a few dead spots.
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: 2 Netgear routers
You could use the 7500 as a wired AP in the area to help cover some dead spots.
Channels would need to be far appart on each router.
I would lower the power output of the 7500 router from 100% to 50% to help lessen noise and interferences between the two routers.
Distances between the two routers should be at least 30 feet or more.
Message 3 of 5
All Replies
microchip8
Master
Put the old one in Access Point mode to provide more coverage
Message 2 of 5
Guru
Message 3 of 5
greenbob
   I didn't realize you could lower pwer output on the 7500. Thank You
Message 4 of 5
Guru
Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 877 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
