- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1750/r6400v2 running V1.0.4.78_10.0.55. how to disable wireless isolation
- Mark as New
- Bookmark
- Subscribe
- Permalink
My issue is the following. My laptop is on 5GHz, my new printer only connects to 2.4GHz.
Since they are on separate networks, my laptop cannot see the printer.
I believe that if I disable wireless isolation, my laptop will be able to see my printer.
BUT, I cannot find the setting to disable wireless isolation.
Is this possible on my model, and if so, how do I do it?
Thanks,
Tom
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What fixed it was that I had to enable the Guest network as well
as the option: Allow guests to see each other and access my local network
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750/r6400v2 running V1.0.4.78_10.0.55. how to disable wireless isolation
Says who? I'm willing to believe that you're having trouble getting
your (unspecified) "my new printer" connected to your router, but who
says that the reason is that "they are on separate networks"?
> to see my printer.
I believe that you're wrong. If your router actually had such
"wireless isolation", then that might make some sense.
Perhaps that's because there is no such setting. On these routers,
the closest thing to any kind of "wireless isolation" is the "Guest
Network", which, I assume, you're not using. In fact, except for the
"Guest Network" stuff, wired and wireless devices (using any radio) all
share the same LAN, and should be able to communicate with each other.
Let me guess. Your (unspecified) "my new printer" is made by
Brother? That "wireless isolation" stuff seems to be the Brother
boilerplate message/explanation for any communication problem.
Occasionally, it might be true.
Knowing nothing about your actual problem (what you did, what
happened when you did it, ...) makes it tough to offer specific advice.
Other than to stop looking for any kind of "wireless isolation" setting,
that is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
