Orbi WiFi 7 RBE973
Reply
APN Nighthawk R7100LG which APN with roaming
evkrieken
Follower
I am using this router only in my camper with a SIM-card, so using mobile broadband. The SIM-card is from Vodafone, the SIM pin is deacticated and roaming is on. So I am travelling through Europe passing continious different networks. My first question is whether I should enter the APN from my own provider (of the SIM-card) or that of the actual delivering provider through roaming? In case of the 2nd one this would mean that I need to change this with every change of provider. Is there another solution?
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: APN Nighthawk R7100LG which APN with roaming
Hi evkrieken,
You should use the APN of the provider within the area since the Vodafone network is no longer available on the said country or area.
Message 2 of 3
All Replies
JamesGL
Master
Hi evkrieken,
Message 2 of 3
JamesGL
Master
Hi evkrieken,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2635 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
