Orbi WiFi 7 RBE973
Reply
BT Home Hub issies
robinlh
BT Home Hub issies
I am trying to connect this product to my BT Home Hub 7 wifi and it is not working consistently. Some TVs connect some do not; some devices seem to be unaffected, some not. Often the device will say it is connected to the wifi but there is no internet.
Any ideas?
Thanks,
Robin
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 4
Guru
Re: BT Home Hub issies
If you set it up using WPS, factory reset the extender and reinstall it using the installation assistant.
Wps can get coded different between manufacturers.
What firmware is on the extender?
What actual bt hub is it?
Message 2 of 4
robinlh
Thanks for your reply. I have already returned the product for a refund. Spent too long trying to get it working already...
Message 3 of 4
BT's HomeHub is the devil's plaything. I have two sitting in boxes, unopened.
When grappling with that pile of junk, it is usually better to consult the fine folk at the BT Forum.
Welcome to BT’s official support community.
The last time I looked there were some knowledgeable and helpful people there.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 392 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
