- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000 resets itself to factory settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It happened four times past two months and it is annoying. Did anyone experience similar trouble? It resets itself randomly to factory settings. Checked power wires and reset it with a reset button on the back. My modem is about two years old so is out of warranty.
Any other help solutions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000 resets itself to factory settings.
Got a screen snip of your cable connections page and event logs?
Usually when I see them resetting, its either been triggered from a firmware upgrade pushed by the isp or a power issue that triggers it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
