Orbi WiFi 7 RBE973
Reply
Connection Issues
raydeo
Connection Issues
As a senior, I am highly frustrated and ready to return my new router to Costco. After working through some of the hiccups today, I am now unable to connect my ROKU 3 to the network (router). The ROKU boots up and freezes showing Not Connected and the remote will not allow me to arrow down to setup. When I took a 25 foot ethernet cable hooking from ROKU box to router, the Port 3 light is shining solid red and there is no connection with the ROKU box.
This happened this morning when I tried connecting the Canon Pixma MX870 to the router via ethernet cable - Port 4 had a solid red light and I had to revert to wireless access with printer/scanner. At least it works now although the thernet cable is still plugged into Port 4 with no light on.
What do I have to do on the router to make the Port 3 and 4 active - didn't need to do anything with the Dell PC or HP Laserjet (just plugged them in and they worked right away).
Thanks in advance for any assistance.
Bruce
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 4
Accepted Solutions
raydeo
Re: Connection Issues
What a difference a day makes.  Able to connect both the ROKU (wirelessly) and Canon Pixma MX870 Port 4 with both working. Still not sure why Port 4 has a red light versus Ports 1 & 2 at white but maybe due to age of printer not being able to communicate at higher speed.
Happy to say router won't be going back to Costco!
Thanks
Bruce
Message 4 of 4
All Replies
You haven't said which Netgear hardware is causing you grief.
Message 2 of 4
raydeo
Sorry Michael, I thought it would show up in the post since the model number was asked for. It's a Nighthawk X6 R7900 Tri Band.
Thanks, Bruce
Message 3 of 4
raydeo
Thanks
Bruce
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3449 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
