- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DC power for D7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
DC power for D7000
When I use a 12 volt car battery to supply the router it will not complete the boot-up sequence. Continuously cycles. Works normally with AC powered wall-wart. Voltage is 12.55 VDC. Have tried two different batteries. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DC power for D7000
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
"A" != "D". D7000[v1] or D7000v2, or what? Look for "Model" on the
product label.
> When I use a 12 volt car battery [...]
With or without the engine running? Cable length?
> [...] Continuously cycles. [...]
That's a little vague. The LEDs flop around as in a normal power-on,
but don't get stable, or what?
I've never tried it, so I know nothing, but I'd expect a bare battery
to work well. A running engine (generator) might add some potentially
troublesome (electrical) noise, but I wouldn't expect it to matter. A
sufficiently long cable might make a local filter/bypass capacitor
desirable close to the load.
I happened to have handy an adapter cable stub which was deformable
into compatibility, so I've now tried it with a D7000[v1]. Worked as
expected (although without Internet access). The LEDs look dim
outdoors, but that's true with the AC adapter, too. My cheap-Chinese
meter said 12.3xV ("x" varied), for what that's worth, with the engine
off.
It did take about a minute and a half to initialize (either way).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
