Orbi WiFi 7 RBE973
Reply
Edit .cfg file from R9000
HemD
Hello..
Is there any way to edit .cfg file (setup backup file) generated from R9000 WiFi router? If not is there a easy way to extract "Block site/Key word" list so that I can copy this to my new AX8 router?
Currently the R900 router is running version 1.0.5.40.
Thanks.
HemD
Message 1 of 3
Guru
Re: Edit .cfg file from R9000
No. Config files are not cross model usable.
Message 2 of 3
The only option that seems to work is to get all the key data in screen shots.
Alt + Print Screen is your friend.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1307 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
