Orbi WiFi 7 RBE973
Reply
Ethernet does not have a valid IP confguration
Heburius
Follower
(Posting this because a person told me to repost in this category)
Okay so, I was trying to plug in my Netgear (using ethernet only, I have ATT fiber if that helps) But I keep getting Unidentified Network error, and when I diagnose, it says Ethernet does not have a valid IP Configuration. Help will be appreciated.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Re: Ethernet does not have a valid IP confguration
Plug your "Netgear" ( R7000P?) into what?
What does "ethernet only" mean to you?
ATT fiber could be many things. ISPs use the label indiscriminately and there is fiber in just about every flavour of Internet.
What does this "Ethernet" come from? Some sort of box on the wall?
Where do you see this Unidentified Network error?
What are you doing to doagnose it?
What shows you the message Ethernet does not have a valid IP Configuration?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done this already. I can't tell from your message.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 253 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
