Orbi WiFi 7 RBE973
Reply
Extensively High ping on wow with R7000
OnesQuared
Guide
My brother recently purchased the R7000 model and after the switch, my WoW ping has been unnatrually high, fluctuating from 12k to 22k.
The firmware was updated earlier today as of ( oct 29/2017)
My pc is on Windows 10, windows firewall has exception for all blizzard products, such as the battle.net app, wow and etc etc.
I run bit defender as anti virus.
I've tried port forwarding with no avail and honestly at a loss on what could solve the issue ,any advice would be appreciated.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 10
Accepted Solutions
OnesQuared
Guide
Re: Extensively High ping on wow with R7000
I solved the issue, atleast for WoW, you just turn off ipv6 from the system-> network
Message 7 of 10
All Replies
William10a
Master
Is your qos turned on or off ?
Message 2 of 10
OnesQuared
Guide
its turned off
Message 3 of 10
William10a
Master
What was your like before the new netgear was install was it a standard modem to router to computer network?
Did the new netgear replace another router or did you just added the netgear after the your old router?
Message 4 of 10
OnesQuared
Guide
I had no issue without the netgear, I was running standard modem+router the isp provided previously.
The netgear was added to the modem, before we were just using the modem
Message 5 of 10
Macbo101
Has anyone had any luck fixing this issue? I feel that this could be the QoS feature wrecking havoc for us....
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 6 of 10
OnesQuared
Guide
Message 7 of 10
Macbo101
You mean in thew PC itself?
Sorry I didnt get it ::P
Message 8 of 10
OnesQuared
Guide
In wow, log in to any char, system -> network, turn off IPv6 and log out and log back in, should fix the ping on wow
Message 9 of 10
Macbo101
This was the fix for me. Thank you very much @OnesQuared What I did was I match the IPv6 config from my PC to the Router and now works flawlesly.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 7427 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
