- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FIOS Quantum Gateway + Orbi + Nighthawk R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm thinking about getting the FlashRouter Nighthawk R9000 to use as a dedicated VPN router. I currently have an Orbi (router & satellite) connected to a Fios Quantum Gateway. Can I use the Nighthawk with the Orbi? Will this impact performance?
I want to route some devices through a VPN (NordVPN Service) but not all. I need the Orbi satellite to boost the WiFi signal since the router is in the basement. We have the satellite connected via ethernet to the orbi router on the 1st floor to help with WiFi on the 2nd floor. We have 16+ devices that connected at any given time. If I can use both, what is the best set up?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes you can use the nighthawk with orbi its suggested to set it to AP mode or connect the orbi to the nighthawk and then put the orbi in ap mode.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
