- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FTP unable to connect from outside
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I set everything up have a dynamic dns and i can access the ftp internally but cannot access the ftp from the outside any suggestion. heres a little I have verizon wireless modem and my router is connected to the modem I have port foward ip ending in .14 which is my nighthawk router port forward port 21
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you look on page 89 of the R7000 manual, you'll see that there are two FTP settings. One to enable local access and one to enable Internet access. You need to enable the latter.
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM_21Dec2015.pdf
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: FTP unable to connect from outside
You have a port forwarding rule where the IP address is the router itself? That doesn't make any sense. You want the port forwarding rule to point to the IP address of the FTP server on your home network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah that what I did I check the routers logs and it says [USB remote access] from xx.xx.xx.xx through FTP, Tuesday, Feb 23,2016 20:42:01but nothing comes up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you set it up to port forward TCP port 21?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes let me try to explain again in case i said something wrong
I have the dynamic dns and i have set up ftp from the net gear router which I can access internally but not from the outside
my modem has a ip of 192.168.xx.xx my net gear routers ips is 192.168.xx.14 so I did a port foward 192.168.xx.14 tcp and udp 21 I am trying to ftp to my usb
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes If I enabled it like I said works internal but not from the outside same thing if I pick the HTTP as well it works internally but not from the outside
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what happened but now it works
- Mark as New
- Bookmark
- Subscribe
- Permalink
