Orbi WiFi 7 RBE973
Reply
Firmware Suggestion
RealDogfart
Guide
Firmware Suggestion
It would be useful, at least to me, to be able to export the Access Control list as a table. To have an "editable" list of equipment with corresponding IP addresses and their MAC addresses would be useful.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: Firmware Suggestion
   Copy+paste from the Web page?  Have you looked at the ".cfg" file
produced by (on my D7000) ADVANCED > Administration > Backup Settings:
Backup Settings?  Perhaps you can extract what you want from that file
(unsightly as it may be).
Message 2 of 4
All Replies
antinode
Guru
Message 2 of 4
RealDogfart
Guide
Copy and paste the web page - Duh... simple and perfect. Thanks. I had PDF'd a screenshot and was trying to get Acrobat to OCR it into something editable. Talk about the long way. It would only OCR about 90% and the rest was junk. Thanks.
Message 3 of 4
antinode
Guru
> Copy and paste the web page [...]
   Or, if using a browser is ok, then save the HTML, and try to extract
the useful data from that.  Perhaps Wget could be persuaded to fetch the
page, if you can get it past the authentication.  Some scripting would
be needed to extract the useful data, no doubt.  But, for a one-timer,
copy+paste can be pretty handy.
   As usual, many things are possible, and there's seldom only one
solution to a problem in this neighborhood.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3879 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
