Orbi WiFi 7 RBE973
Reply
Firmware update failure for R8000P version
DavePel
I have been trying off and on since I got this router to update the firmware, it is currently sitting at V1.4.1.50_1.3.10.  I have tried the automatic update and manual upload to install R8000P-V1.4.1.68_1.3.28, when using the GUI, I get an error saying it couldn't update the firmware, when I do a manual upload, it seems to go quite quickly, then reboots, but does not update firmware.  This is mildly annoying as my ASSUMPTION is there was a reason why newer firmware revisions were built.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
ssundblade
Re: Firmware update failure for R8000P version
Good luck getting any resolution. I have been working for weeks on resolving this and searching this board etc...with no luck.
Might as well return it now if you can and buy a new router as you will never get past that update if it hasn't worked.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 421 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
