Orbi WiFi 7 RBE973
Reply
First Timer...
e_Anon
Tutor
First Timer...
Hi All,
I was wondering what would be an ideal setup for my home and office.
3,000 sq ft House/ ATT Fiber Optic 1G
-Master bedroom closet will have the switch panel (CAT 5E)
-2nd Floor Ceiling (CAT 5E Outlet)
-Downstairs Office (CAT 5E Outlet)
Which products do you recommend and should they be placed?
Assuming the ATT Modem will stay in the closet upstairs. I should have a router downstairs in my office and a Access Point upstairs on the ceiling.
Looking forward to any advise.
Message 1 of 6
Guru
Re: First Timer...
I'm a fan of mesh systems (orbi/mk nighthawk). Especially if you're planning on having a router +access point.
Is the one with "ceiling" going to be powered with POE?
Message 2 of 6
e_Anon
Tutor
Re: First Timer...
Thanks for responding! yes the ceiling will be POE.
Message 3 of 6
Guru
Re: First Timer...
the orbi pro (AC versions) has a satellite that can run of POE.
https://www.netgear.com/business/wifi/mesh/src60/
Might be worth checking out to get like a SRK60 system and add in the SRC60.
That'd give you a router, standard satellite, and a POE satellite.
Message 4 of 6
e_Anon
Tutor
Re: First Timer...
Thank you! I will definitely be looking into that!
I appreciate your advice!
Message 5 of 6
Guru
Re: First Timer...
good luck! Hope thats the type of setup you're looking for!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 765 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
