- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to change my password for netgear.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help. I figured it out by logging out and then clicking that I could not remember my password rather than asking for a one time password. They then sent me a link to re-set the password.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to change my password for netgear.com
Does it give a Forgot Password option?
https://kb.netgear.com/000038785/How-do-I-reset-my-NETGEAR-account-password
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. It sent me a single use password. I planned on going in and changing my password but can't figure out where to do that. Logically, it should be in the profile section but . . . as with a lot with this website, I don't find it logical, and can't find it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its under Manage Profile/Log In Settings...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like they did figure it out. Thanks for posting though.
@emmyjohn01 wrote:
You can go login page then try to rest your password. i hope you can succesfuly reset your password.try it thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SJPWOLFF wrote:Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
i think you need to go login dashbord and click on reset password then reset and re enter new paassword.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That only works for the router log in, not the netgear.com user account.
