Orbi WiFi 7 RBE973
Reply
How to check prior Logs for Netgear Router R7800
jetman024
Follower
Every couple hours our Nighthawlk router loses wifi. All the lights turn off for a second then turn orange before regaining signal. Our modem does not lose signal and ISP confirms service was not lost. When I check the log it only shows data from when it reconnects. Is there a way to check the log prior to losing service? Anyone else have this issue?
Thanks
Message 1 of 4
JayboH
Apprentice
Re: How to check prior Logs for Netgear Router R7800
Which firmware do you have on it?  Is it .76?
Message 2 of 4
canepa
Tutor
If your firmware is 1.0.2.76 or 1.0.2.74 you should revert to version 1.0.2.68
You can find more information here:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-76/m-p/2007947
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 3 of 4
JayboH
Apprentice
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure.  When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker:  do NOT restore your saved settings.  Put them in manually one by one.
I haven't had any issues at all now.  You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
Message 4 of 4
Discussion stats
  • 3 replies
  • 1107 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
