Reply
How to unbrick the Nighthawk R7000 using OS X and TFTP
waymer66
Re: How to unbrick the Nighthawk R7000 using OS X and TFTP
I have followed the instructions to the letter, as outlined in the first post:
Ran a cable from the computer directly to the first LAN port.
Opened System Preferences/Network and keyed in the following:
Configure IPv4: Manually
IP Address: 192.168.1.10
Subnet Mask: 255.255.255.0
Router: (left blank)
I opened up the terminal and commanded it to the desktop. I opened another window in the terminal and entered “ping 192.168.1.1”.
I get the message Request timeout for icmp_seq (number).
What am I doing wrong or is this proof that the router is toast? Thanks.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 51 of 75
antinode
Guru
   It's evidence that the router is not responding as expected.  But
you've joined a years-old discussion and provided little information
about your own situation.  Starting your own thread for your own problem
might make more sense.
   Is that your model?  Connected to what?
   LED indicators?  Any other symptoms?  Have you done a settings reset?
Message 52 of 75
waymer66
I had a friend who is an engineer walk me through the steps as outlined previously again. It's bricked, so I ordered a mesh system from a company that doesn't encourage it's customers to trash their routers via auotmatic updating.
Message 53 of 75
antinode
Guru
> outlined previously again. [...]
   Did he tell you how to answer basic questions, too?  Apparently not.
Message 54 of 75
techtherapy
thanks so much for the guide @kryptonix, you saved me a lot of time Smiley Happy
Message 55 of 75
seethelight
Hi guys, fantastic summary. It works perfectly until the very last point. When i type put _ name of the file after few second i receive the message "transfer timed out".
The shell with the ping repietely have the following lines:
Request timeout for icmp_seq 1874
Request timeout for icmp_seq 1875
Request timeout for icmp_seq 1876
64 bytes from 192.168.1.1: icmp_seq=1877 ttl=63 time=1.824 ms
64 bytes from 192.168.1.1: icmp_seq=1878 ttl=63 time=1.571 ms
64 bytes from 192.168.1.1: icmp_seq=1879 ttl=63 time=1.780 ms
Request timeout for icmp_seq 1880
Request timeout for icmp_seq 1881
Request timeout for icmp_seq 1882
Request timeout for icmp_seq 1883
ping: sendto: No route to host
Request timeout for icmp_seq 1884
ping: sendto: Host is down
Request timeout for icmp_seq 1885
Request timeout for icmp_seq 1886
Request timeout for icmp_seq 1887
anyone would be able to advise how i can get the last step done? it seems to me that the router keeps rebooting so that there is no enough time to transfer the new firmware?
Message 56 of 75
seethelight
Apologies for the multiple messages, diregard the previous one.
Some context first:
I have a r8000 which i understand is very similar to r8000 in terms of troubleshooting. I was trying to flash the router with Advance tomato. The firmware seemed to be correctly installed but clearly this was not the case as after the installation was completed the router got stuck in what i believe is a reboot loop. after spending pratically all night trying to resolve it I came across this post. I followed all the steps mentioned and i got until the last one where after i send the command to install the latest version of original netgear firmware i receive the message, like many others above, "request timed out".
I diligently read the advise that @antinode gave to previous users and therefore see below the copy and paste from the two shells i have used to type the commands.
Shell with commands:
Last login: Tue Nov 24 01:48:43 on ttys001
diego@Dies-Air ~ % ls
Applications
Creative Cloud Files
Desktop
Documents
Downloads
Library
Movies
Music
OneDrive
Pictures
Public
iCloud Drive (Archive)
diego@Dies-Air ~ % cd desktop
diego@Dies-Air desktop % ls
Accounts.xlsx TFTP Client 2.app
DS_Store.txt TFTP Client.app
Documents Transfer_1.3.dmg
FOTO (EXPORT) Worksheet 2019:2020v1.xls
R8000-V1.0.4.62_10.1.74 nmrpflash
R8000-V1.0.4.62_10.1.74.chk nmrpflash-0.9.14-macos.zip
R8000-V1.0.4.62_10.1.74.zip tftp_client_122_intel.zip
diego@Dies-Air desktop % tftp
tftp> connect 192.168.1.1
tftp> status
Connected to 192.168.1.1.
Mode: netascii Verbose: off Tracing: off
Rexmt-interval: 5 seconds, Max-timeout: 25 seconds
tftp> binary
tftp> put R8000-V1.0.4.62_10.1.74.chk
Transfer timed out.
SHELL WITH PING
Last login: Tue Nov 24 01:54:42 on ttys001
diego@Dies-Air desktop % ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=100 time=25.285 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=100 time=2.573 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=100 time=2.495 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=100 time=2.499 ms
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
Request timeout for icmp_seq 9
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
Request timeout for icmp_seq 19
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
Request timeout for icmp_seq 25
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
Request timeout for icmp_seq 33
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
Request timeout for icmp_seq 36
Request timeout for icmp_seq 37
Request timeout for icmp_seq 38
Request timeout for icmp_seq 39
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
Request timeout for icmp_seq 42
Request timeout for icmp_seq 43
Request timeout for icmp_seq 44
Request timeout for icmp_seq 45
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
Request timeout for icmp_seq 49
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
64 bytes from 192.168.1.1: icmp_seq=49 ttl=100 time=3631.749 ms
64 bytes from 192.168.1.1: icmp_seq=50 ttl=100 time=2630.577 ms
64 bytes from 192.168.1.1: icmp_seq=53 ttl=100 time=2.544 ms
64 bytes from 192.168.1.1: icmp_seq=54 ttl=100 time=2.523 ms
64 bytes from 192.168.1.1: icmp_seq=55 ttl=100 time=2.076 ms
64 bytes from 192.168.1.1: icmp_seq=56 ttl=100 time=2.541 ms
Request timeout for icmp_seq 58
Request timeout for icmp_seq 59
Request timeout for icmp_seq 60
Request timeout for icmp_seq 61
Request timeout for icmp_seq 62
Request timeout for icmp_seq 63
Request timeout for icmp_seq 64
Request timeout for icmp_seq 65
Request timeout for icmp_seq 66
Request timeout for icmp_seq 67
Request timeout for icmp_seq 68
Request timeout for icmp_seq 69
Request timeout for icmp_seq 70
Request timeout for icmp_seq 71
Request timeout for icmp_seq 72
Request timeout for icmp_seq 73
Request timeout for icmp_seq 74
Request timeout for icmp_seq 75
Request timeout for icmp_seq 76
Request timeout for icmp_seq 77
Request timeout for icmp_seq 78
Request timeout for icmp_seq 79
Request timeout for icmp_seq 80
Request timeout for icmp_seq 81
Request timeout for icmp_seq 82
Request timeout for icmp_seq 83
Request timeout for icmp_seq 84
Request timeout for icmp_seq 85
Request timeout for icmp_seq 86
Request timeout for icmp_seq 87
Request timeout for icmp_seq 88
Request timeout for icmp_seq 89
Request timeout for icmp_seq 90
Request timeout for icmp_seq 91
Request timeout for icmp_seq 92
Request timeout for icmp_seq 93
Request timeout for icmp_seq 94
Request timeout for icmp_seq 95
Request timeout for icmp_seq 96
Request timeout for icmp_seq 97
Request timeout for icmp_seq 98
Request timeout for icmp_seq 99
Request timeout for icmp_seq 100
Request timeout for icmp_seq 101
Request timeout for icmp_seq 102
Request timeout for icmp_seq 103
Request timeout for icmp_seq 104
64 bytes from 192.168.1.1: icmp_seq=105 ttl=100 time=5.389 ms
64 bytes from 192.168.1.1: icmp_seq=106 ttl=100 time=2.545 ms
64 bytes from 192.168.1.1: icmp_seq=107 ttl=100 time=2.514 ms
64 bytes from 192.168.1.1: icmp_seq=108 ttl=100 time=2.599 ms
Request timeout for icmp_seq 109
it seems to me that there is no enough time to install the firmare as the router keeps re-booting?
@techtherapy @kryptonix @antinode  any guidance much appreciated -
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 57 of 75
kryptonix
Guide
Quick reply - when you LS your desktop, the file is not listed. Unpack the zip file with the chk, put the chk on the desktop then try again;)
Senior Designer
Message 58 of 75
antinode
Guru
   That can be a problem.  I'd try fiddling with power-on and Reset
timing, hoping to get lucky.
   If you can't find a time window when it works, then you might need to
bring out the big guns, like opening the box and attaching a serial port
adapter, and using that to interrupt whatever it's doing.  A Web search
for terms like, say:
      netgear serial port
should find more information.
> Quick reply - when you LS your desktop, the file is not listed. [...]
   Try a slower reply?  I see it there.  Did the program complain about
"No such file or directory"?  "ls" and "ls -1" are different.  (So is
"LS".)  File names which include spaces can cause confusion, too.
Message 59 of 75
vijay_amrit
Tutor
Wow, i was trying to unbrick my router and came across this. The other solutions i found needed a client that is not compatible with newer versions of MacOS. This has very clear istructions one can follow. One thing i noticed was that while trying to ping, i only got 'Request timeout' message. However there was no problem in connecting and uploading the firmware. Thanks a lot
Model: R6120|AC1200 Dual Band WiFi Router
Message 60 of 75
vijay_amrit
Tutor
@seethelight just proceed with next step. i got request timout message during ping too. however rest of the steps worked well.
Message 61 of 75
I have an R6700 and this is the closest thread I've found to mirror my issue. After getting to the last page, I notice I'm having the same exact problem as @seethelight . My router keeps rebooting constantly and, via the ping command, I notice that it's only on for 4 seconds, and then restarts again, running through the restart loop for 93 seconds, at which point it's connected again for 4 seconds and back to restart.
Seems like this is not enough time to execute the TFTP command.. Wondering if anyone found a solution to this? I tried using a different power adapter and problem persists, so the power source is not the issue. Tried hard resets but also doesn't help.
PS: this happened after I set the router to repeater mode.
PS2: not sure if I should open a new thread?
Here's the file in my desktop, using an old one because it was the one that ran more stable before this mess:
Last login: Sun Jan 10 11:04:46 on ttys000
Brunos-MacBook-Air-2:~ bruno$ cd desktop
Brunos-MacBook-Air-2:desktop bruno$ ls
R6700-V1.0.1.20_10.0.32.chk
Here is the reboot pattern. I leave the router on and it does this forever:
Last login: Sun Jan 10 11:06:38 on ttys001
Brunos-MacBook-Air-2:~ bruno$ ping 192.168.1.1
Request timeout for icmp_seq 0
64 bytes from 192.168.1.1: icmp_seq=15 ttl=100 time=3.081 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=100 time=1.577 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=100 time=1.630 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=100 time=1.417 ms
And here is the TFTP command I'm running. I'm doing the put exactly when I get the first ttl=100 response from the separate terminal window where I'm pinging the router:
Last login: Sun Jan 10 11:07:33 on ttys001
Brunos-MacBook-Air-2:desktop bruno$ tftp
tftp> status
tftp> binary
tftp> status
Mode: octet Verbose: off Tracing: off
tftp> put R6700-V1.0.1.20_10.0.32.chk
Transfer timed out.
tftp>
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 62 of 75
seethelight
unfortunately i wasnt able to resolve it. Still hoping that someone pops up here with a solution. I also tried with the 4 pins cable but to no avail. If someone could post here all the steps to follow with the 4 pins and mac would be great but to date i have no solution to offer.
Message 63 of 75
jparkerBBIT
same here mate.  Netgear is garbage
Message 64 of 75
Jatayu
Re: How to unbrick the Nighthawk R6850 using OS X and TFTP
Hi ,
Followed the commands and unable to transfer the file.
Receiving - Transfer timed out
Message 65 of 75
itsmevgupta
Hi
Thanks for the detailed steps. I have tried your method.
1. I get ping from the router only for few seconds and then it keeps getting timed out
2. When I use the Put command to transfer the firmware, I keep getting "Transfer timed out". I'm guessing that is because of step 1.
I am also noticing that my router is in a constant restart cycle on its own. Pressing the RESET button is not doing anything either. Please let me know if you have any suggestions?
Model: R7000|AC1900 Smart WIFI Router
Message 66 of 75
itsmevgupta
Did you find any resolution to this? I am running into the same issue and my router is in a constant restart loop.
Message 67 of 75
Did not. At this point I’m just gonna toss it in the trash can
Message 68 of 75
seethelight
That’s exactly what I did. Tossed it out
Message 69 of 75
itsmevgupta
I finally managed to fix mine. Used the other method nmpr flash method.
https://github.com/jclehner/nmrpflash
Message 70 of 75
Super silly question coming from someone who is not well versed with terminal (or any coding)... how do I actually install nmrpflash? I downloaded it for Mac OS, navigated to the directory where it's at in Terminal, but then typing "nmrpflash -L" gives me nothing...
-->xxxxxx:~/Downloads$ nmrpflash -L
-bash: nmrpflash: command not found
Message 71 of 75
itsmevgupta
There is no silly question @brunomartorella . Infact, I was running into this exact same issue earlier. The key is to copy the downloaded files onto the desktop. and then execute the steps below:
1. Download the latest firmware from the Netgear website and extract it to your desktop. I had the .chk file on my desktop.
2. Follow the instructions here to set a static IP. FWIW, I left my Router entry blank.
3. Use an ethernet cord to connect to the router (one of the LAN ports, not the internet port).
4. Download macOS file here: https://github.com/jclehner/nmrpflash/releases
5. Extract the zip file to your desktop as well
5. Open terminal, type
cd desktop
6. Then, I followed the instructions in the github page. These are the commands I used specifically:
./nmrpflash -L
to pull up the list of connections and find the name of my ethernet port connected to the router (Find the one with IP 192.168.1.10)
7. Then you turn OFF the router.
8. For the rest of this example, let's assume that your router is connected to eth2, and that you want to flash a firmware image named R7000-V1.0.11.128_10.2.112.chk.
sudo ./nmrpflash -i eth2 -f R7000-V1.0.11.128_10.2.112.chk
Enter your mac password if you are asked for it.
Then I got the response
Waiting for physical connection
9. And then I turned on my router. I did have the reset button pushed in while turning it on. Release the button after about 10 seconds.
After that, it should do its thing. You will see some messages in terminal but sometimes there will be a minute or two with no updates, just wait. It took about 5 minutes, I just had to wait. Once nmrpflash tells you to reboot your device, do so and it should work now.
10. The last step I had to do was to reconfigure my router as I am using it as a repeater.
Hope this helps. Let me know if there are any questions.
Message 72 of 75
Gahhh I was missing the ./ oops
Anyway, tried it and it doesn't work. Both with and without the reset button. I think the router and its very short reboot cycle don't allow it to transfer the file, which is the same problem as I had with tftp. It's funny because I execute it in verbose mode and it seems like it's transferring data out "<< DATA (n)" where n changes every few seconds to n+1. But then it keeps on doing that even after I power the router down, which means it's really not doing anything.
Message 73 of 75
HOLY COW IT WORKED!!!
nmrpflash worked!!! Switching to a Static IP address and turning my Wifi off did the trick!!
Also, recommend using -vvv to double check when it works. Took me two tries to nail the timing because the router has to finish restarting for the packet transfer to begin before the command times out.
Message 74 of 75
itsmevgupta
@brunomartorella  Great job!! Glad we were able to motivate each other Smiley Very Happy
Message 75 of 75
Discussion stats
Announcements
Orbi WiFi 6E
