Orbi WiFi 7 RBE973
Reply
Model WNDR3400v3 LAN Ports
OldGrouchy
Follower
Are the LAN ports connected to the input Ethernet port if the power is off?
Murray
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Model WNDR3400v3 LAN Ports
> off?
   An Ethernet interface is bidirectional; there are no input ports or
output ports.
   When the router power is off, _all_ its Ethernet ports, LAN or
WAN/Internet, are inactive.  Just like its USB port.  And its everything
else.
   On a router (or network switch) there's never a direct/passive
connection between one Ethernet port and another; there is always some
electronics between them.  No power, no connection.
   Is there some actual problem which you are trying to solve?
Message 2 of 2
All Replies
antinode
Guru
> off?
output ports.
else.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 395 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
