Orbi WiFi 7 RBE973
Reply
Netgear Newbie Nighthawk AC1900 Cable Modem Router
chrob61
Hello all-
When I purchased my new router last week at Best Buy, I immediately called my internet provider, who helped me with the set up.   I just told him the MAC number and he did all the workings behind the scenes for me.   So far so good.   Then I needed to go to my Alexa devices, my phone, and my rokus and enter in the new internet password (on the side sticker).   BUT, I forgot about my wifi thermostat.   So I am trying to find how to access the router settings where you sign in using admin.....
I'd like to have a desktop link that I can use to sign in to my router's settings.   Is this possible, or am I missing something?   I did say I was a Netgear newbie!!
Thanks!!
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 4
Accepted Solutions
Guru
Re: Netgear Newbie Nighthawk AC1900 Cable Modem Router
you can find the manuals here that have additional info.
https://www.netgear.com/support/product/c7000.aspx
Message 4 of 4
All Replies
Guru
yes you can sign in using a desktop.
What modem/router did you buy? AC1900 is a speed, not a model.
try hardwiring in a device and going to routerlogin . com
or 192.168.100.1
Message 2 of 4
chrob61
Model number is C7000 I fixed my header, I think.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1385 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
