iAmBlue
May 28, 2020Tutor
Netgear R7000 Rebooting Randomly - Isn't hot to the touch
Hello, I'm having a problem with my R7000 where it will reboot about once per day. Below are my current specs:
Model: Netgear R7000
Firmware: V1.0.9.88_10.2.88
OS: Stock OS
Environment: Normal home at 76°F, enough space for sufficient airflow to router
I've tried switching the location of the router and connecting it to different power outlets, but the same problem keeps occuring. I saw people discussing this issue with the R7000, and it being heat, but when I feel the top and bottom of the router, it is warm, like a normal router would. I have even went as far as resetting my router completely, but it still keeps happening. If someone could help me out I would appreciate it.
The other thing you see a lot of on here is issues with the firmware for the r7000.
have you tried changing firmware?
I'd recommend version 1.0.9.42. Downgrade to that over a hardwired connection, factory reset the router back to stock, and manually install it.
Then disable auto updates and see how it does.
- alceryesTutor
Make sure your router is receiving proper NTP data from Netgear or the NTP you listed. (if in the US you can use us.pool.ntp.org)
- iAmBlueTutorIt’s on the default settings, with the time zone being est where I live and NTP server set to the default Netgear one.
- iAmBlueTutor
Thanks, it worked. I took a day or two to test it and make sure it didn't reboot or do anything funky, which it didn't. It's just weird how netgear wouldn't fix something major like that with their firmware...
- plemansGuru - Experienced UserProblem with it is that not all devices have the problem. Otherwise it probably would be an easy fix. But for the devices that do have issues, for some reason the 1.0.9.42 firmware tends to work well.
