Orbi WiFi 7 RBE973
Reply
Netgear router r7350
billy82390
Follower
I just had ISP out at my house. They tested all my connections and have found that the bottlenecking is due to my router. I have a cm2000 netgear modem and cat6 from the modem to the r7350 router. and then cat 7 to the pc. My ISP package is 1200mbps download. I get around 900 with my cat 6 directly from my modem to PC. When its Modem to router to PC I am getting at most 525mbps download. Everything is up to date with firmware. I've tried a bunch of different things, but I can't seem to figure it out.
Message 1 of 2
Kitsap
Master
Re: Netgear router r7350
It is difficult to imagine what the "bunch of different things" are that you have tried.
One approach would be to do a firmware (factory) default reset and setup the router from scratch.
Leave the basic default configuration as is with the following exceptions:
Make sure QOS is not enabled, UPnP is not enabled, and traffic meter is not enabled.
When you are done with the configuration, power down (disconnect the power cord) on both your modem and your router.  Wait a couple of minutes and power up your modem.  Give it plenty of time to boot, establish a connection with your ISP, and stabilize.  Now power up your router and give it plenty of time to boot and stabilize.
Now run your tests.
If your ISP supports IPv6, enable it on your router under advanced settings.
Message 2 of 2
Discussion stats
  • 1 reply
  • 719 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
