Orbi WiFi 7 RBE973
Reply
Never seemed to work properly
PW05
I have had this for a few years now and it has never seemed to be of any benefit just using electricity in the corner. I recently received an email about a Firmware update so after a great deal of trouble loggining in and trying to update it I am asked to connect to NETGEAR_EXT. in settings. I tried on both my phone and computer and neither can find this address. Can anyone out there help me set this up to start working. I was not convinced it was connected when first purchased but now quite sure
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 13
Accepted Solutions
Guru
Re: Never seemed to work properly
Then factory reset it and start over.
Push and hold reset for 7-15 seconds while its powered on.
then follow the install guide and use the installation assistant method and NOT wps.
Message 12 of 13
All Replies
Guru
You already had it setup?
Its a mesh extender so it uses the same ssid as the primary router and devices roam between the primary router and it as needed.
so it doesn't show up as seperate. Its the whole purpose of a mesh device is that you don't have to mess with it or switch between networks. Your device handles it all.
If you log into your router, it'll have an attached device list (or equivelent). Look at that list for the EX7700's IP address and use its ip address to connect to it.
Message 2 of 13
PW05
OK thanks for that. Then how do I update the Firmware as it doesn't like the Netgear_Ext. address?
Message 3 of 13
Guru
Are you sure that's your SSID and not someone elses?
Have you tried logging into the extender to see what firmware its on? You might be on the latest as the email updates are just sent to everyone with that registered device.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Message 4 of 13
PW05
when I go to bullet 2 of the installation instructions of New Features and Enhancements I receive a message saying unable to connect?, I have tried again and waited as suggested but still the same result
Message 5 of 13
Guru
not sure what you mean under "new features and enhancements", got a screen snip?
have you simply tried factory resetting the extender and starting back at stock settings?
Message 6 of 13
PW05
Message 7 of 13
Guru
Is the extender setup and working?
What are its led's doing?
Message 8 of 13
PW05
I have 3 white LED's on the front, it is set up as far as I know, I am not by any means tech savy but followed the intructions. With regard resetting to factory settings, I can't login so no idea how to do that
Message 9 of 13
Guru
If you log into your router, there's an attached devices page (or equivlent depending on your router).
It'll list the ip address for your extender.
go to that address.
What do you see?
Message 10 of 13
PW05
I don't see my extender in any list
Message 11 of 13
Guru
Message 12 of 13
PW05
Thanks I will give it a go
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1370 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
