- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R6700v3 - slow speed over wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I switched my modem to CM1100 and updated plan to 600mbps download speed. I tried wired connection with my modem and I am getting 600-650 mbps speed. I tried wired connection with my router as well. However, I am getting only 200-250 mbps over the wifi. I did factory reset, changed firmware version from 1.0.4.106 (latest) to previous (1.0.4.102) still getting low speed.
Does anyone know whats the fix? Which version will work?
Thanks in advance..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R6700v3 - slow speed over wifi
You are not going to see 600Mbps on your wireless. What you are getting my be as good as it gets. Lot of the speed is determined by the client. You did not specify client.
Here is some good reading to give you everything you wanted to know, but were afraid to ask. Lots of good info.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the link. It is really useful indeed.
P.S: I am using macbook pro 16" 2019 to run speed tests.
