Orbi WiFi 7 RBE973
Reply
Nighthawk R6900P Router
NormS1
Follower
Hello, Anyone know where to get the Nighthawk app. The only place I have found it is on Google. Blocked from Google. Long story, not worth reading. You would think Amazon would provide it since they sell the  router but no luck there. Appreciate any help. Thanks
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Guru
Re: Nighthawk R6900P Router
Reason you need the app?
You can change settings using the browser
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 388 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
