Orbi WiFi 7 RBE973
Reply
Nighthawk R7000P - 5ghz not working
tylerlcarlson
Follower
My 5ghz stopped working all of a sudden. Tried resetting and rebooting to no avail… firmware is reportedly up to date. V1.3.2.134.
Tried SmartConnect and separate 5ghz network and nothing is working. Any ideas?
Message 1 of 4
Re: Nighthawk R7000P - 5ghz not working
The key word there is "reportedly". In reality that is an old version from two years ago. There have been half a dozen since then.
The latest I have is R7000P-V1.3.3.154_10.1.86
R7000P Firmware Version 1.3.3.154 | Answer | NETGEAR Support – undefined
I'd start with that.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 4
Molarka
Hello there,
I am also facing similar probem with my laptop while usingfree Picsart. But I have solved this problem. When You have coonected router with laptop then Internet have connected but on Internet connection it will show no internet connection sign. It is happened due to slow speed of laptop. So with increaing the speed of the laptop you wil overcome this problem.
Message 3 of 4
Linkspam with nonsense message.
IGNORE.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1120 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
