- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7960P Router and NO-IP No Longer Play Together
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've searched other posts about this issue, but none of the suggested solutions seem to work.
My Nighthawk R7960P router's Dynamic DNS function no longer seems to work. I have used this feature along with port forwarding to feed an audio stream to an Icecast server running on a little single-board computer (Odroid); it has worked flawlessly for the last year or so.
My No-IP account shows things are working, but when I click Show Status on the router, I receive this:
"Update failed at 06:14PM,12/17/2021 The service provider is not reachable."
I really can't use No-IP's Dynamic Update Client (DUC) because the Icecast server is running Linux Mate.
Router firmware is V1.4.1.50_1.3.10, which is out-of-date, but attempts to update never work (a separate problem).
Thoughts, suggestions, and recipes welcome!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7960P Router and NO-IP No Longer Play Together
I have the OpenVPN server configured and have a No-IP account. When I click on the Show Status in the router Advanced Setup -> Dynamic DNS page the return is No update action. There is no IP address on the Internet port. The OpenVPN server works fine.
My No-IP account is configured as DNS Host (A) and the account page shows 91 updates in the past 30 days. When I go to the whatismyipaddress.com site it provides the correct IPv4 and IPv6 addresses. I am not running the Dynamic Update Client (DUC).
What is your type configuration for your No-IP account? Please confirm your R7960 is configured in router mode. What is the brand and model of the modem/gateway/ONT in front of your router?
You might want to get to the bottom of the firmware update issue first. Your DDNS issue could solve itself.
