- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R8000 one of the 5GHz is not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Experts,
Device: Netgear Nighthawk X6 AC3200
FW Version: v1.0.4.84
My Nighthawk R8000 X6 is broadcasting two 5GHz SSIDs. One of them is using Channel 44 (Radio 1) and other one is using Channel 153 (Radio 2)
None of my devices (Android phone, Windows 11 PC, outdoor video camera etc) are able to connect to Channel 44 based 5GHz SSID, where as all my devices are able to connect to Channel 153 based 5GHz SSID just fine.
I am not sure how to fix this issue. I have tried rebooting several times. After reboot 5GHz Radio 1 works fine for few mins and then none of the devices are able to connect to it.
Kindly please help to resolve this issue. I have many connected devices in the house and current situation is causing lot of problems.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R8000 one of the 5GHz is not working
What error do you get when you try to connect?
did you try a simple factory reset?
