Orbi WiFi 7 RBE973
Reply
Nighthawk X10 R9000 Uptade
Eduardo0569
Follower
I have a Nighthawk X10 R9000 router, after the last update, it has crashed and it does not start any more. The flashing white light goes on, the other LEDs are off, I need your help, if anyone knows a solution to this problem, try resetting more not solved.
Message 1 of 2
Accepted Solutions
Re: Nighthawk X10 R9000 Uptade
Sadly, you may be in TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Did you try the  more serious reset?
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
Message 2 of 2
All Replies
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1746 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
