Orbi WiFi 7 RBE973
Reply
Nighthawk X4 R7500v2 Access Control does not work
motorbikematt
Frustrating behavior with my  device, router firmware version V1.0.3.10
I cannot block a device that is using my network.
Advanced>Security>Access Control
the checkbox next to Turn On Access Control is  checked.
I go to the list of the devices that are currently connected, indicating "Allowed" under the status. I click the checkbox next to any of them (for example, an iPad my cousin is addicted to).   I then click the "Block" button.
I get a popup that asks:
"Do you really want to block access to selected device(s)?"
I select OK.
Screen refreshes,  nothing happens; the device still says Allowed!
I've rebooted the device twice, no luck!
Anybody else have this issue?
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 6
Accepted Solutions
JamesGL
Master
Re: Nighthawk X4 R7500v2 Access Control does not work
Hi motorbikematt,
Try to reset the router to factory default and manually reconfigure the device.
Message 4 of 6
All Replies
JamesGL
Master
Hi motorbikematt,
I tried to replicate your concern but I was not able to reproduce the same behavior. Mine works fine.
Message 2 of 6
motorbikematt
Thank you for trying to replicate!! That is interesting data, even if it isn't a solution.
Tell me, when did you buy yours? Is it 'younger' than mine?
Message 3 of 6
JamesGL
Master
Hi motorbikematt,
Message 4 of 6
JamesGL
Master
Hi motorbikematt,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 6
Dodd52
I have the same router and the same issue.  I can't block an intruder in my network.  I bought my router in Dec 2015.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3506 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
