Orbi WiFi 7 RBE973
Reply
Nighthawk X6 R8000 ethernet ports not working after power outage...
mdashwin
Follower
Hi,
My nighthawk x6 R8000 none of the ethernet ports including the cable in port is working after power outage. I have tried the factory reset. I am not able to TFTP and reload the firware as none of the ports are getting detected... Any help is greatly appreciated.
Thanks
mdashwin
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: Nighthawk X6 R8000 ethernet ports not working after power outage...
what are the led's on it doing?
Tftp/nmrpflash work by using a static ip address to fix bricked devices.
Did you try them?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 726 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
