Orbi WiFi 7 RBE973
Reply
Nighthawk X6S R8000P and CM1150V modem
2much
Tutor
Hello everyone,
I recently upgraded to gig speed with xfinity and purchased a CM1150V modem and a R8000P router . modem boots fine and everything seemed ok until i hooked the router. At first everything seems fine i get wifi setup and then connect other devices to the wifi.
my network is this 2 iphones 2 smart tvs on 5GHz band wifi a Xbox one x wired from router and a pc wired from router. out of the blue the upload will start blinking on the modem or the modem will start a soft reboot. when i say soft reboot i mean it starts from download then upload then Internet then phone. xfinity don't want to seem to help because signals are good. Any help would be great.
On another note , i can hook my old linksys ea6900 and have no problems.
Am i missing some setting in the router i need to change? i dont change no settings in the router but for the wifi names and passwords.
Message 1 of 3
Accepted Solutions
2much
Tutor
Re: Nighthawk X6S R8000P and CM1150V modem
never mind I am done with it . Returning the thing.
Message 2 of 3
All Replies
2much
Tutor
Message 2 of 3
myersw
Master
Probably a good move as the r8000p has lots of firmware issues.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1385 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
