- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk x6 r8000 blocked Origin client to login
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have a issue with my router. I cant connect to either the Origin client "you need to be online to login" or if a surf in to www.origin.com the page loads in about 30sek and then when you click sign in it said "the webpage cant be found" ??!
Ive tried everything from google like delete all, reinstall, open ports, downgrade router 1 step, tried every settings in the router, firewall and so on..
I have also tried a laptop and it dosent work, BUT ! when i activate my VPN on the laptop i does work without any problem ??!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk x6 r8000 blocked Origin client to login
The next day it worked again like a charm to access Origin Web and the Client. Today its locked out again. WTF is the problem with this router ??
If a connect with my laptop and VPN i worked good. And if i connect my Old Asus router it does work to ?
