Orbi WiFi 7 RBE973
Reply
No internet without bridge
fredbaker
Hello,
My previous setup of Motorla modem >> Ooma Hub >> R7000P worked fine for years, but after the Ooma Hub's recent death and rewiring the modem's output straight into the router, no internet will pass over wifi (the router still puts out a wifi signal, but it contains no data).
What do I need to do to make this work without the Hub bridging the two devices?
Thank you.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 6
Accepted Solutions
Guru
Re: No internet without bridge
Has a power off for 1 minute then back ON with the ISP modem and router?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 4 of 6
All Replies
Guru
Message 2 of 6
fredbaker
My modem is Arris SURFboard SB6141
Since there is no wifi in my house, I can't log into my Netgear software, so I don't know the firmware version. Is there another way to log in?
Message 3 of 6
Guru
Message 4 of 6
fredbaker
I did that several times already with the same result. I just did it again, same thing.
However this last time I noticed an ethernet cable was plugged in the back of the router that wasn't connected to anything (the previous computer was pulled out some time ago). So I removed that and rebooted again and this time it worked. I have no idea why that would have made a difference, but it's working now and I'm not touching anything.
Thanks for your help.
Message 5 of 6
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1491 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
