- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orange / Red light on my netgear nighthawk router
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ethernet port on my netgear skyhawk router shows orange/red where I have my arlo base station plugged into .The arlo base station shows a flashing orange light for the internet light. I am not sure what the problem is. Anyone familier with this situation? I would appreciate any help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, the base station is connected but I was having trouble with one of my cameras going off line and thought the amber light meant a weak signal. I thought it was suppose to be white. I appreciate your info. Answers my question and Netgear is replacing the camera. The amber light is not the issue. Thank you michaelkenward.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orange / Red light on my netgear nighthawk router
The colour of the ethernet lights is usually an indication of the speed they are running at.
Orange = 100 Mbps Green = 1000 Mbps.
Solved: Netgear Router WNDR4500 port is orange for Arlo ba... - NETGEAR Communities
Are you saying that the base station isn't connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
