Orbi WiFi 7 RBE973
Reply
Port forwarding not working R7000
pwatkins30
Follower
Hello,
I am having trouble getting Port Forwarding working on my AC1750 router. It seems to be a software issue with it. I am not able to add ports, or computers, or anything to the Port Forwarding/ Port Triggering list. When I try to add one it seems to just glitch out and not add it. Attached below I have a recording of what is going on.
I am trying to port a Plex Media Server, using port 32400 on a static IP with Windows 10. My cable modem is a motorola.
https://www.dropbox.com/s/f7uzfo7hz3gxkyh/2017-03-09%2008-17-51.mp4?dl=0
Model: R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 9
Accepted Solutions
SteelGlaze
Re: Port forwarding not working R7000
Great suggestions.
I flashed my router with DD-WRT firmware and everything worked as expected re port forwarding.
Flashed back to stock firmware, and now that's working too.  Don't know why, but glat its working now regardless.
Message 7 of 9
All Replies
JamesGL
Master
Hi pwatkins30,
1. What is the firmware version of the router? Make sure to update it.
2. If it is updated, reset the router to factory default and manually reconfigure.
Message 2 of 9
TheEther
Guru
OP has a R6700 not a R7000.  The firmware version is visible in the video.  It's 1.0.1.16_10.0.30.
Message 3 of 9
SteelGlaze
Same issue on my r7000.  Port forwarding not working.  It used to.   I have static IP's assigned by the router to various IP's on my network via MAC address.   Ports are forwarded, FTP on one PC, remote desktop port on another, and so on.  All no longer working.  I triple checked the config, it is right.  Turned off all Windows firewalls etc.  No dice.  Been using online port checkers to verify my ports are in fact blocked.  They are.
Updated firmware to   V1.0.7.10_1.2.3.  Still everything is blocked.  So frustrating!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 4 of 9
SteelGlaze
I reset the router to factory default settings.  Manually reentered the DHCP assignment and forwarded the port to said internal IP.  Disabled Windows Firewall on that machine.
Checked with port checker on the machine the port is forwarded to.  PORT STILL CLOSED
WTH???  Why is port forwarding BROKEN on my router?????
This is so frustrating!
Message 5 of 9
JamesGL
Master
Hi SteelGlaze,
While doing port checker, make sure the app that uses the port is running. Also if you bypass the router, will it work?
Message 6 of 9
SteelGlaze
Great suggestions.
Message 7 of 9
CarlWatkins
I tried the earlier version firmare 1.0.8.34, but no dice again.  So where can I find the original factory firmware, DD-WRT?  It's not listed in the Netgear software and firmware downloads page.
Message 8 of 9
antinode
Guru
   First, you might do better in this forum if you opened a new thread
and described your own problem, rather than awakening some old thread
which might be vaguely related (and which is marked as solved).
   As a basic Web search would show, DD-WRT is not "the original factory
firmware" for a typical Netgear product.
      http://www.dd-wrt.com/site/index
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 12856 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
