- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R-8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
R-8000
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
What router do you have?
You put r8000 in your title but C7500 in the signature.
What firmware is on it?
Did you try a factory reset followed by a clean install (not from backup)?
Make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
Model: R8000
Firmware: V1.0.4.68_10.1.75
Yeah I’ve done several factory restarts. The only thing I do in the router settings is activate the 5GHz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
Some of the r8000's had issues with netgear armor.
Try installing version 1.0.4.28 of the firmware over a hardwired connection, then do a factory reset and a clean install (not from a backup).
Then disable auto-updates and try it for a bit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
I would highly recommend installing from a hardwired pc/laptop connection. When we see corrupt firmware issues, it tends to be people who've done it over a wireless/app install process.
You can get the firmware here:
https://www.netgear.com/support/product/r8000
under downloads--->view previous version.
By clean install, I just mean don't use a backup configuration that you've saved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
What do I do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
> I downloaded the firmware [...]
What, exactly, did you download? Actual file name?
> [...] but when I go to router up date. Select upgrade I find the down
> load and select it.
What, exactly, is your "the down load"? Actual file name? Hint:
Anything ending in ".zip" is wrong.
> I extract all and it says you are attempting to open a file of type
> `System File' (.chk) [...]
"it says" that when you do _what_, exactly?
> What do I do?
You might start with an oft-neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"firmware". When that fails because of a deficient User Manual, try:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
Once it download it, I select the file “R8000-V1.0.4.28_10.1.54.zip” open it. Then select the “R8000-V1.0.4.28_10.1.54.chk” file. A pop up window appear and says “You are attempting to open a file of type System file (.chk)
These file are used by the operating system and by various programs. Editing or modifying them could damage your system”
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
> [...] Then select the "R8000-V1.0.4.28_10.1.54.chk" file. [...]
There's a difference between "select" (single-click) and "open"
(double-click), but you should be doihg neither.
> https://kb.netgear.com/23960
> https://community.netgear.com/t5/x/x/m-p/1721037#M124018
Read them again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
I made a video so you can see exactly what I’m doing.
https://youtu.be/DRuw99CLyQU
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
> I did the instructions you gave me [...]
I disagree. Exactly which "the instructions" do you believe that
you're following? Where, exactly, did you see an instruction (or even a
suggestion) to click on the ".chk" file in a File Explorer window?
> I made a video so you can see exactly what I'm doing.
That was painful. Which part of 'you should not be asking the OS to
"open" it' was unclear?
> Read them again?
Still my advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
The release notes for the firmware you download should have detailed instructions.
Then there is this.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
@Nofear202 wrote:
I’m only having problems with unzipping the folder.
Does this mean that you do not know how to unzip a file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
Thank you so much, I was going crazy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
You should not need any extra software. Windows and Macs have built in zip support.
I just downloaded both R8000-V1.0.4.28_10.1.54.zip (listed in your earlier message) and R8000-V1.0.4.68_10.1.75.zip (the newest) They unzipped without any problem. I simply drag and drop from within the zip; on to my desktop. I do have a fancy file manager but you shouldn't need that.
https://www.netgear.com/support/product/r8000.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R-8000
@Nofear202 wrote:
I ran a speed test on the Xbox and it gave me 830 mbs. Now I’m trying to update a game but I’m only getting 350 mbs?
If that is a wifi speed, it is pretty damn good.
When the Xbox says 830 Mbps, that tells us that your router is not far off the best it can deliver. Wifi speeds are down to the client (receiver) technology. You'll have a hard time finding clients that get 830 Mbps. I doubt if the wifi from the R8000 is up to that.
Forget about the measurements, look at what happens. Do you have any problems with a game at 350 Mbps? Most games and streaming services are fine at a tenth of that speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
