Orbi WiFi 7 RBE973
Reply
R5700v3
Thekizman
R5700v3
 Router lists all in one printer with one IP address.  Printer lists another ip address.  Printer works but wont scan
Message 1 of 5
Re: R5700v3
Not much useful information in there. This isn't the telegram era, where every word cost money.
What router is this? R5700v3 doesn't exist. R7500v3?
What is this printer?
How does it connect to to your network? Wifi? Wire ethernet?
Message 2 of 5
Thekizman
Re: R5700v3
My mistake.  the router is an Netgear R6700V3.  the printer is connected via wifi.  The router is less than five feet from the printer.  the printer copiews, prints but will not scan.
Message 3 of 5
Kitsap
Master
Re: R5700v3
You still have not answered the question about the printer.  What is the brand and model number?
Wi-Fi will be the least satisfactory connection for a multi-function printer/scanner.  The most satisfactory connection will be by connecting your multi-function device directly to your router/LAN via an Ethernet cable.
The unnamed printer manufacturer most likely has a configuration application to setup your printer and scanner.
Message 4 of 5
Re: R5700v3
For example:
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
or
ij network tool - Canon UK
It is generally down to the printer to play ball with the wifi, not the other way round.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 677 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
