Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6350 - AC1750 Nighthawk login - username
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-30
12:01 PM
2020-12-30
12:01 PM
Trying to login to the Nighthawk app to update the firmware (per email from Netgear). I can login on the Netgear website (using my email and password). On the app under username it says "admin". I had changed username when I first bought the router, but the app is not permitting changing the username and am unable to login.
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-30
12:14 PM
2020-12-30
12:14 PM
Re: R6350 - AC1750 Nighthawk login - username
Don't use crappy apps for updates unless you want to brick your router
Do not use WiFi either for firmware updates. It's unreliable
Use a wired connection to the router and go to http://192.168.1.1
Message 2 of 2
Announcements
