- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 Connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
R6700 Connections
Nighthawk R6700/AC1750
We use this router to connect devices to our sound board (Allen & Heath QU-32) We connect to the Network port of the sound board to the port 2 of the ethernet side of the router and we can connect and control the board just fine. My question is how do we share this particular router with broadcasting a Wifi signal ? Currently we have to switch from the router for the sound board to the router we use for in-house Wifi..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 Connections
Is the wifi broadcasting?
Did you try to connect to the wifi?
Did you log into the router and setup the ssid/password?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
